lumbar&abdominal pressure model
Hi every body
I designed and fabricated a new device for measuring of 3 Axial
Torque(Mx,My,Mz) about L5/S1 or L4/L5 and …
I want compare my experimental results with AnyBody.
In this device I fix pelvic of subject and fasten Thorax to a Back-Pad
and ask subject to exert his/her MVC.
We bought this software recently and I found that in Free Posture
model I can luck pelvic but I have very questions about it like:
1- how can I modify this model that it exert his MVC?
2- Does this model(Free Posture) have Abdominal Pressure effects?
3- If I want run this model in complex posture
(like:20’flexoin-20’R-Lateral Bending-10R-Twist) what should I do?
Please guide me about this.
Mahmood Reza Azghani
PhD Candidate-Biomechanical Dep.
Sharif university of tech.
Hi every body
I designed and fabricated new device for measuring Isometric 3Axial
torque about every level of Lumbar.
We bought Any body recently and I want compare my experimental results
with AnyBody and validate model.
I fix the Pelvic of person and fasten his/her Thorax to a Back-Pad and
I ask him/her to exert his/her MVC.
I have problems to model this exertion.
I found that in the FreePosture model I can lock the pelvic but Does
it have Abdominal Pressure effect ?
If I want test the person in complex posture like “20Felextion-10
right-lateral Bending,15 right twisting” how can I get my model to this
position?
Please guide me about it.
Sharif University of Tech.
Teharn-Iran
Hi Mahmood
Welcome to the group
It sounds as a interesting problem and experiment
The abdominal pressure is present in all models which have muscles
on the spine. If it is an advantage for the model to make use of the
abdominal in order to lower the activities, it will do this.
In the “FreePostureMove” model you can give vectors for each dof in
the Mannequin.any file. In this was you can specify complex motions.
The FreePostureMove model is very similar to the FreePosture model,
the only difference is that takes vectors instead of fixed numbers
as input in the mannequin.any file.
Please ask again if you have further questions.
— In anyscript@yahoogroups.com, “marazghani” <marazghani@…>
wrote:
> Hi every body
results
and
Does
this
> position?
> Teharn-Iran
Hi Mahmood
I think the previous posting will answer question two an three,
number one is still remaining though.
You can not specify directly that you want the model to do MVC, you
will need to do this indirectly by specifying the speed of the
motion in such a way that the muscle activities reach a level of
one, this will be equivalent to MVC.
wrote:
> Hi every body
Pad
