How can i measure angles between two segment when i do the kinematics analysis?
You can use AnyKinRotational class object to measure angles between two segments.
I guess that you can choose either ‘RotAxesAngles’ or ‘DirCosines’ option as the ‘Type’ of AnyKinRotational class object.
I would suggest you to see the reference manual for that class.
