I’m not 100% sure because you haven’t upload your model.
But in case when you have some joint muscles in your model, then it may happen.
For instance, if you are using GaitLowerExtremity model instead of GaitFullBody model,
then because there are some joint muscles in the upper body instead of real muscles,
so this kind of error may happen.
In the GaitLowerExtremity model, because there are no muscle models inside the upper body joints, we introduced the joint muscles.
Joint muscles are in form of AnyGeneralMuscle object. And they are generating the required torques on the human joints.
If you can increase the strength of these joint muscles, then your model may work.
But I’m not sure.
This place is self-supported forum. So you can’t expect our official help here.
When you upload your model, please write also your version of AMS and AMMR.
