Dear all
I have been trying to set up a model of a flexing knee, based on motion capture data from 3 markers on the tibia and femur respectively. When running my script, no errors appear, though no motion appears either when I run the kinematic analysis.
As far as I believe, something is going wrong at the point of the interpolation of the C3D data. When digging in the C3D data, I find my data points under ‘Holder1_1.Pos’, though the interpolated values are just zero (Holder1_1.PosInterpol.Data). I tried to modify the interpolation type though this really didn’t solve the issue.
Does anybody has a suggestion on this?
thanks in advance!
Matthias
ps: I had to modify the extension of my “.c3d” file to .txt since I was not able to upload this file otherwise (so you probably need to set it back if you want to analyse it)
