MoCap driven FreePostureMove
I have attempted to use MoCap data to drive FreePostureMove. The
ARep files are in the uploaded file shippen_FreePostureTtrial.zip.
The only modification I have made to the BRep is to replace the
revolute joint between the neck and skull with a sphereical one (and
the appropriate drivers). This modification seems to have been
sucessful.
However when I use the MoCap data I receive many error messages of
the type:
Constraint no. 191 above error tolerance 0.000001, error = 0.000002. -
constr. #1
in ‘Main.Model.ModelEnvironmentConnection.Drivers.AnkleDriverRight’
Constraint no. 192 above error tolerance 0.000001, error = 0.000005. -
constr. #0
in ‘Main.Model.ModelEnvironmentConnection.Drivers.HipDriverLeft’
Constraint no. 194 above error tolerance 0.000001, error = 0.000006. -
constr. #2
Constraint no. 196 above error tolerance 0.000001, error = 0.000005. -
constr. #0
in ‘Main.Model.ModelEnvironmentConnection.Drivers.AnkleDriverLeft’
ERROR(OBJ.MCH.KIN3) : C:\research\Repository.6\Repository.6
\ARep\Aalborg\FreePostureTrial\FreePostureMove.Main.any
(80) : ‘Study’ : Kinematic analysis failed in time step 0
Does that mean anything to you?
Thanks
James Shippen
Hi Robin
I get the error:
ERROR(OBJ.MCH.KIN2) :
H:\Dokumenter\2b\AnyBody\ARep\Aalborg\FreePostureTrial\FreePostureMove.Main.any(
80)
: ‘Study’ : Model is kinematically over-constrained : Position
analysis failed : 2 unsolvable constraint(s) found
when I run your model.
The one you get, sounds like one you can remove by putting a
KinematicTol into the study. The error you describes comes because
there, for some reason is some kinematic problems, as far as I remember.
Christian, AnyBody Support
— In anyscript@yahoogroups.com, “jamesshippen” <jamesshippen@…> wrote:
> Hi
> sucessful.
> the type:
> constr. #1
> constr. #0
> constr. #2
> constr. #0
> Thanks
> James Shippen
Hi Christian,
I’m not sure if you are replying to James’ or my question. =)
Robin
> Hi Robin
> I get the error:
80)
> Best regards
> — In anyscript@yahoogroups.com, “jamesshippen” <jamesshippen@> wrote:
> > Hi
> > sucessful.
> > the type:
> > constr. #1
> > constr. #0
> > constr. #2
> > constr. #0
> > Thanks
> > James Shippen
Hi Christian (and Robin)
I think the reply was directed at me at the suggestion certainly had
an affect on my model.
By introducting a kinematic tolerance of slightly greater than
reported in the error message, no further errors were reported,
however nor was there any movement of the figure during
kinematicAnalysis.
The plot thickens! All suggestions appreciated.
Ta!
James
wrote:
> Hi Robin
> I get the error:
.Main.any(80)
remember.
> Best regards
wrote:
> > Hi
(and
> > sucessful.
of
> > the type:
0.000002. -
> > constr. #1
0.000005. -
> > constr. #0
0.000006. -
> > constr. #2
0.000005. -
> > constr. #0
> > Thanks
> > James Shippen
Hi James
Yes… the answer was for you;-)
I am not sure what you mean?
> kinematicAnalysis.
> Ta!
> James
> wrote:
> > Hi Robin
> > I get the error:
> .Main.any(80)
> remember.
> > Best regards
> wrote:
> > > Hi
> (and
> > > sucessful.
> of
> > > the type:
> 0.000002. -
> > > constr. #1
> 0.000005. -
> > > constr. #0
> 0.000006. -
> > > constr. #2
> 0.000005. -
> > > constr. #0
> > > Thanks
> > > James Shippen
Hi Robin
Sorry… I will look at your now,
— In anyscript@yahoogroups.com, “Robin” <giggsyagami07@…> wrote:
> Hi Christian,
> Regards,
> Robin
> — In anyscript@yahoogroups.com, “AnyBody Support” <support@> wrote:
> > Hi Robin
> > I get the error:
80)
remember.
> > Best regards
wrote:
> > > Hi
(and
> > > sucessful.
> > > the type:
0.000002. -
> > > constr. #1
0.000005. -
> > > constr. #0
0.000006. -
> > > constr. #2
0.000005. -
> > > constr. #0
> > > Thanks
> > > James Shippen
Hi Chistian,
I’ve made some progress since. So currently you don’t have to look at
my problem (yet). =)
As usual, I will come back should I come to a dead end.
Thanks
Regards
Robin
> Hi Robin
> Best regards
> — In anyscript@yahoogroups.com, “Robin” <giggsyagami07@> wrote:
> > Hi Christian,
> > Regards,
> > Robin
> > > Hi Robin
> > > I get the error:
80)
> remember.
> > > Best regards
> wrote:
> > > > Hi
> (and
> > > > sucessful.
messages of
> > > > the type:
> 0.000002. -
> > > > constr. #1
> > > > in
> 0.000005. -
> > > > constr. #0
> 0.000006. -
> > > > constr. #2
> 0.000005. -
> > > > constr. #0
> > > > Thanks
> > > > James Shippen
With no kinematic tolerance specificed (presumably defaulting to 1e-
6?) the final kinematic erro was 4.17. I therefore specified a
tolerance of 5.
The kinematicAnalysis then reported that all of the steps had been
completed however there was no segmental motion displayed in the
Model View; also the high speed with which the model executed
suggested that no processing was being performed.
I have uploaded the files to shippen_no_movement.zip.
Thanks
James
> Hi James
> Best regards
had
> > kinematicAnalysis.
> > Ta!
> > James
> > wrote:
> > > Hi Robin
> > > I get the error:
> > .Main.any(80)
Position
because
> > remember.
> > > Best regards
<jamesshippen@>
> > wrote:
> > > > Hi
The
the
one
> > (and
been
> > > > sucessful.
messages
> > of
> > > > the type:
> > 0.000002. -
> > > > constr. #1
> > 0.000005. -
> > > > constr. #0
> > 0.000006. -
> > > > constr. #2
> > 0.000005. -
> > > > constr. #0
> > > > Thanks
> > > > James Shippen
Hi James
I have looked at your model and found a bug in it.
When i tried to run the kinematic analysis it tells that the model
is kinematically overconstrained with two dofs.
I checked in the JointAndDrivers.any file and found that the neck is
driven with all three rotations. This is not possible since the neck
joint is a revolute joint. So i removed all of them except the
flexion.
In general for a running model then when you add a driver to the
model you should always also remove a driver, to keep balance in the
DOF count.
However this was still not enough to make the model run
kinematically, i have found that if the rotation around y is above
90 deg then the model do not run, please jsut try to lower the
rotations around y. This is because the initial position of the
pelvis is calculated differently than the way it is driven in the
JointsAndDriver.any file, please have a look in the
InitialPosition.any file also for the details. For some reason which
it turns out that for a y angle larger than -90 the starting guess
is not a good one.
So please try to reduce this angle and keep it below this value.
Alternatively you can turn the global reference system around.
By setting the KinematicTol=5 it means that the kinematic error is
allowed to be 5m. So when you try to solve the kinemtatics it
already is solved because the error toleranceon the kinemtatics is
so high, this is why it do not move. So in general it should be
left as the default value.
I hope this helps you to move on, oherwise please ask again.
wrote:
> Hi
1e-
> tolerance of 5.
> Thanks
> James
> > Hi James
> > Best regards
certainly
> had
reported,
> > > kinematicAnalysis.
> > > Ta!
> > > James
> > > wrote:
> > > > Hi Robin
> > > > I get the error:
e
> > > .Main.any(80)
> Position
> because
I
> > > remember.
> > > > Best regards
> <jamesshippen@>
> > > wrote:
> > > > > Hi
FreePostureMove.
> The
replace
> the
sphereical
> one
> > > (and
> been
> > > > > sucessful.
> messages
> > > of
> > > > > the type:
> > > 0.000002. -
> > > > > constr. #1
> > > 0.000005. -
> > > > > constr. #0
> > > 0.000006. -
> > > > > constr. #2
> > > 0.000005. -
> > > > > constr. #0
\Repository.6
step 0
> > > > > Thanks
> > > > > James Shippen
Hi Søren
Not so much a bug; more a feature!!! I replaced the revolute joint
in the neck with a sphereical one which is more appropriate for the
MoCap data I am using.
Many thanks for the information with regard to rotations in excess of
+/-90. I rotated the model about gobal axes to reduce one of the
tilt/obquitity/pitch angles to a mean of zero, and the model ran.
Thanks
James
wrote:
> Hi James
is
neck
> flexion.
the
> DOF count.
which
> is not a good one.
> Best regards
> wrote:
> > Hi
> 1e-
> > tolerance of 5.
been
> > Thanks
> > James
> > > Hi James
> > > Best regards
<jamesshippen@>
> certainly
> > had
than
> reported,
> > > > kinematicAnalysis.
> > > > Ta!
> > > > James
<support@>
> > > > wrote:
> > > > > Hi Robin
> > > > > I get the error:
> e
> > > > .Main.any(80)
> > Position
> > because
as
> I
> > > > remember.
> > > > > Best regards
> > <jamesshippen@>
> > > > wrote:
> > > > > > Hi
> FreePostureMove.
> > The
> replace
> > the
> sphereical
> > one
> > > > (and
have
> > been
> > > > > > sucessful.
> > messages
> > > > of
> > > > > > the type:
> > > > 0.000002. -
> > > > > > constr. #1
> > > > 0.000005. -
> > > > > > constr. #0
> > > > 0.000006. -
> > > > > > constr. #2
> > > > 0.000005. -
> > > > > > constr. #0
> \Repository.6
> step 0
> > > > > > Thanks
> > > > > > James Shippen
Hi James
Good that the model is running now.
Sorry about the neck joint, i did realize that you changed it :wink:
wrote:
> Hi Søren
joint
the
of
> Thanks
> James
> wrote:
> > Hi James
model
neck
> is
> neck
> > flexion.
the
> the
> > DOF count.
above
the
> which
guess
> > is not a good one.
is
is
> > Best regards
> > wrote:
> > > Hi
to
> > 1e-
a
> > > tolerance of 5.
> been
the
> > > Thanks
> > > James
wrote:
> > > > Hi James
> > > > Best regards
> <jamesshippen@>
> > certainly
> > > had
> than
> > reported,
> > > > > kinematicAnalysis.
> > > > > Ta!
> > > > > James
> <support@>
> > > > > wrote:
> > > > > > Hi Robin
> > > > > > I get the error:
> > e
> > > > > .Main.any(80)
constrained :
> > > Position
putting a
comes
> > > because
far
> as
> > I
> > > > > remember.
> > > > > > Best regards
> > > <jamesshippen@>
> > > > > wrote:
> > > > > > > Hi
> > FreePostureMove.
> > > The
> > replace
> > > the
> > sphereical
> > > one
> > > > > (and
> have
> > > been
> > > > > > > sucessful.
> > > messages
> > > > > of
> > > > > > > the type:
error
> > > > > 0.000002. -
> > > > > > > constr. #1
error
> > > > > 0.000005. -
> > > > > > > constr. #0
error
> > > > > 0.000006. -
> > > > > > > constr. #2
error
> > > > > 0.000005. -
> > > > > > > constr. #0
> > \Repository.6
time
> > step 0
> > > > > > > Thanks
> > > > > > > James Shippen
