hello,
I want to run the GM MoCAP foot model.But when I load the model,one error appears as following:
Evaluating constants…
ERROR(SCR.EXP.FUN.EXT4) : C:/P…s/A…y/A…0/AMMR/A…n/Beta/M…t/S…g/RBFLandmarks.any(78) : ReadMLFile : AnyBody.Python extension module is not installed or does not match installed version of Python.
Model loading skipped
I have installed the python according to the instruction.
And add the following words in the top of AnyBody main file #path ANYBODY_PATH_PYTHONHOME “D:\Anaconda2\envs\py37_foot”.I have tried many times,but it always failed.
Could you please give me some suggestions?Thank you!
Thanks for your message!
I have paid attention to the problems that you mentioned. As for the software,
AMS and python are both 64 bit and python version is 2.7.
But the error still exists.
I guess if the sentence #path ANYBODY_PATH_PYTHONHOME “D:\Anaconda2\envs\py37_foot” is not right.Or
something else causes the problem.
John
Hi John,
You probably have changed the name in the env, but i noticed you have the env as :
when the anybody website has the location as :
\Anaconda2\envs\py27_foot.
AnybodySite:
To create and use the environment please follow these two steps:
Open a prompt
write: conda create --name py27_foot --file FootModelPython_spec_file.txt
in the top of your AnyBody main file please write : #path ANYBODY_PATH_PYTHONHOME “TYPE_IN_YOUR_PATH_TO_ANACONDA\Continuum\Anaconda2\envs\py27_foot”
You should double check your #path file is correct (location and any potential admin blocks) and that the start of line 24 of the ReadMeshIn is changed from a tab to 4 spaces.
Attached is the edited ReadMeshLabIn file with the edit.
