I am using a mocap model to drive the mechanics of a designed exoskeleton.
I have the problem that one essential marker in my mocap sequence becomes visible only after half of the time. The interpolation function is in this case not suitable, because the position of the interpolation result of the marker is not correct. Is it possible to only use the marker trajectory information, if the marker was visible and measured? So that would mean, that the solver doesn't take the marker information of the first half of the sequence into account, but drives my exoskeleton when the relevant marker appears.
I am using this code:
AnyKinDriverMarker MarkerExoskeleton =
CType = {Soft,Soft,Soft};
AnyRefFrame &Marker= Main.ModelSetup.C3DFileData.Points.Markers.ExoMarker.PosInterpol;
AnyParamFun &Trajectory = Main.EnvironmentModel.Exoskeleton.Assembly___1.Node1;
Thanks!
David
