MoCap Model right arm/detailed hand
As already described in the Forum I have problems with running my inverse dynamic analysis because my system is kinematically overconstrained.
I uploaded the model here. I am working with AMMR.v1.6.2 and Anybody Version 6.0.
Thanks in advance,
Christin.
I found the problem. The inverse dynmaics is running now.
Christin.
Could you share the solution to this problem? I also have a overconstrained model in InverseDynamics analysis while it runs with the MotionOptimization.
