Dear experts:
I am using MoCapModel in AMMR 1.6.1, ABS6.0.1 to calculate the muscle / joint forces. I wanted to define a local coordinate system at the knee by adding the following in the environment.any:
[SIZE=3] AnySeg[/SIZE] &LeTibia = Main.Studies.HumanModel.BodyModel.Left.Leg.Seg.Shank;
LeTibia = {
[SIZE=3]AnyRefNode[/SIZE] localrefframe = {
sRel = {0.05,-0.45,-0.02};
[SIZE=3]AnyDrawRefFrame[/SIZE] drws = {ScaleXYZ = {1,1,1}*0.3; RGB={0,0,1};};
I am having the following problems:
- if I simply used the knee or shank segment, the coordinates showed up at the hip. That’s why I changed sRel and now the location of the local coor. seems right.
- Then I started Inverse dynamic analysis, and got the following error messages. I didn’t have such errors if I use global coordinate system.
Any suggestion will be greatly appreciated!!
[SIZE=1] WARNING(OBJ.MCH.KIN9)[/SIZE] : [SIZE=1]C:/P…s/A…y/A…0/AMMR/Body/A…n/T…x/W…s/WrappingCylinder5PointFit.any(36)[/SIZE] : [SIZE=1]cyl[/SIZE] : Problems at calculation of closest point : Newton algorithm for finding closest point not converged, result could be inaccurate!
[SIZE=1] ERROR(OBJ.MCH.MUS4)[/SIZE] : [SIZE=1]D:/Gait …ysis/M…0/M…l/InverseDynamics.any(29)[/SIZE] : [SIZE=1]InverseDynamicStudy.InverseDynamics[/SIZE] : Muscle recruitment solver : solver aborted after maximum number of line-search iterations
