I want to do a gait experiment up and down the stairs. I plan to put the wooden blocks on the force plate to simulate the situation of going up and down stairs.Due to the addition of wooden blocks, the gravity of the blocks also affects the results. How should I modify it when I run MoCapModel in Anybody? Thank you in advance.
You can create however many ‘stairs’ you want out of your blocks, just make sure to zero the force plates once the blocks are situated/before recording motion capture.
