miralija
(miralija)
July 5, 2016, 3:19pm
1
Hi everyone!
I am trying to load different *.c3d files (frames ~7000) into the MoCap Model - but just the following error massage appears (for each file with ~7000 frames):
ERROR(SYS1) : Model load : Unknown error
All my other *.c3d files (frames ~1500) are working just fine (MotionAndParameterOptimization + InverseDynamicModel).
Is the captured file just too large or do I have to consider something else?
Mira
Hello Mira
This indeed sounds like the file is too large, and you probably are running into memory issues on your computer.
A solution could be to split the file up.
If it is possible for you to share the file with us, we could investigate the error further.
Kasper Pihl Rasmussen
miralija
(miralija)
July 6, 2016, 12:16pm
3
Hello Mr. Rasmussen,
thank you very much for your quick reply.
I attached an example file, which is not possible to laod in AnyBody. If you need further codings, just let me know!
Mira
Hello Mija
Could you share your Markers.any file, so I don’t have to modify the model also?
miralija
(miralija)
July 14, 2016, 3:31pm
5
please find attached the Markers.any file.
Mira
Hello Mira
I can’t seem to replicate your unknown error; the c3d file is working fine for me.
Do you also get the error if you cut/split the same c3d file into smaller pieces?
miralija
(miralija)
July 28, 2016, 2:30pm
7
Thank you very much for your help!
Sorry for my late reply: I just changed the PC, so know everything just works perfectly.
Mira
