Dear Anybody Community
I would like to perform a moment arm evaluation using the script in the Validation Folder and, therefore, I would like to activate the shoulder rhythm.
I get the following error but could not yet figure out where to inactivate those drivers leading to the overconstraint. I have been using the shoulder rhythm succesfully so far in the freepostrue model.
Looking forward to your comment!
Thank you and all the best,
Johanna
Constraint violations for study 'Main.HumanModel.EvaluateMomentArms.Right.Arm.GHExternalRotation_0Abd.Study' :
Constraint #28 is above tolerance 1e-06, error = 0.110636, constr. #0 in 'Main.HumanModel.BodyModel.Trunk.JointsCervicalSpine.Flexion.CervicalFlexionRhythmDrv'.
Constraint #68 is above tolerance 1e-06, error = 0.007861, constr. #2 in 'Main.HumanModel.BodyModel.Trunk.JointsLumbar.SpineRhythmDrv'.
Constraint #71 is above tolerance 1e-06, error = 0.117248, constr. #5 in 'Main.HumanModel.BodyModel.Trunk.JointsLumbar.SpineRhythmDrv'.
Constraint #74 is above tolerance 1e-06, error = 0.044481, constr. #8 in 'Main.HumanModel.BodyModel.Trunk.JointsLumbar.SpineRhythmDrv'.
Constraint #77 is above tolerance 1e-06, error = 0.064000, constr. #11 in 'Main.HumanModel.BodyModel.Trunk.JointsLumbar.SpineRhythmDrv'.
Constraint #80 is above tolerance 1e-06, error = 0.082558, constr. #14 in 'Main.HumanModel.BodyModel.Trunk.JointsLumbar.SpineRhythmDrv'.
Constraint #83 is above tolerance 1e-06, error = 0.101029, constr. #17 in 'Main.HumanModel.BodyModel.Trunk.JointsLumbar.SpineRhythmDrv'.
Constraint #94 is above tolerance 1e-06, error = 0.008000, constr. #1 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.FE.Constraints'.
Constraint #95 is above tolerance 1e-06, error = 0.000001, constr. #2 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.FE.Constraints'.
Constraint #98 is above tolerance 1e-06, error = 0.005558, constr. #0 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.PSProximalConstraints'.
Constraint #99 is above tolerance 1e-06, error = 0.000436, constr. #1 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.PSProximalConstraints'.
Constraint #100 is above tolerance 1e-06, error = 0.004250, constr. #2 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.PSProximalConstraints'.
Constraint #101 is above tolerance 1e-06, error = 0.003239, constr. #0 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.PSLinDistalConstraint'.
Constraint #102 is above tolerance 1e-06, error = 0.011390, constr. #1 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.PSLinDistalConstraint'.
Constraint #113 is above tolerance 1e-06, error = 0.000536, constr. #0 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.ScapulaAIThoraxNodeDriver'.
Constraint #114 is above tolerance 1e-06, error = 0.655352, constr. #0 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.SternoClavicularRotationRhythm'.
Constraint #115 is above tolerance 1e-06, error = 0.002742, constr. #0 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.ScapulaTSThoraxNodeDriver'.
Constraint #116 is above tolerance 1e-06, error = 0.000003, constr. #0 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.ConoideumLigamentDrv'.
Constraint #117 is above tolerance 1e-06, error = 0.027552, constr. #0 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.ClaviculaProtractionDriver'.
Constraint #118 is above tolerance 1e-06, error = 0.100552, constr. #0 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.ClaviculaElevationDriver'.
Constraint #119 is above tolerance 1e-06, error = 0.004015, constr. #0 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.HandGloveLinDrv'.
Constraint #120 is above tolerance 1e-06, error = 0.006344, constr. #1 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.HandGloveLinDrv'.
Constraint #121 is above tolerance 1e-06, error = 0.000796, constr. #2 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.HandGloveLinDrv'.
Constraint #155 is above tolerance 1e-06, error = 0.017632, constr. #0 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Mus.Pectoralis_minor2_cyl.Cylinder.SphericalJoint.Constraints'.
Constraint #156 is above tolerance 1e-06, error = 0.014847, constr. #1 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Mus.Pectoralis_minor2_cyl.Cylinder.SphericalJoint.Constraints'.
Constraint #157 is above tolerance 1e-06, error = 0.014319, constr. #2 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Mus.Pectoralis_minor2_cyl.Cylinder.SphericalJoint.Constraints'.
Constraint #160 is above tolerance 1e-06, error = 0.560826, constr. #0 in 'Main.HumanModel.BodyModel.Right.ShoulderArm.Mus.Pectoralis_minor2_cyl.Cylinder.CylRotDrv2'.
Constraint #173 is above tolerance 1e-06, error = 0.001281, constr. #0 in 'Main.HumanModel.EvaluateMomentArms.Right.Arm.GHExternalRotation_0Abd.Model.Drivers.ArmDriver'.
Constraint #174 is above tolerance 1e-06, error = 0.006465, constr. #1 in 'Main.HumanModel.EvaluateMomentArms.Right.Arm.GHExternalRotation_0Abd.Model.Drivers.ArmDriver'.
Constraint #176 is above tolerance 1e-06, error = 0.174533, constr. #3 in 'Main.HumanModel.EvaluateMomentArms.Right.Arm.GHExternalRotation_0Abd.Model.Drivers.ArmDriver'.
Constraint #177 is above tolerance 1e-06, error = 0.872665, constr. #4 in 'Main.HumanModel.EvaluateMomentArms.Right.Arm.GHExternalRotation_0Abd.Model.Drivers.ArmDriver'.
Constraint #178 is above tolerance 1e-06, error = 1.570622, constr. #5 in 'Main.HumanModel.EvaluateMomentArms.Right.Arm.GHExternalRotation_0Abd.Model.Drivers.ArmDriver'.
Constraint #179 is above tolerance 1e-06, error = 0.349066, constr. #6 in 'Main.HumanModel.EvaluateMomentArms.Right.Arm.GHExternalRotation_0Abd.Model.Drivers.ArmDriver'.
ERROR(OBJ.MCH.KIN2) : EvaluateMomentArmsStudy.any(61) : Study.InitialConditions : Model is kinematically over-constrained
