I want to develop a thoracic spine model. As I am very new with the software, I thought that it will be nice to start analyzing the motion segment that I will create. Currently, I am working on a motion segment of T3/T4 vertebra.
As a first step, I want to make the joint between these two segments (please see the attachement, T3/T4 joint) to have six d.o.f… At this joint, a stifness
matrix (6x6) will be incorporated. Upon driving the base joint of segment T4, I want to measure the forces in the ligaments and reactions at these joints
under a given force (F) applied at upper segment. Can you please explain how to do this? How can I define a six d.o.f. joint? How can I drive a six d.o.f.
joint in AnyBody? A simple example will be great.
I also attached my simple code, in case it is needed.
Thank you for the reply. Based on your suggestions I made some modififications to my model, and learnt a lot, but still need some help. The new model is as follows:
T3T4Jnt as a spherical joint with added stiffness in translational directions.
BaseJnt as a six dof joint with its position and movement are fixed.
To implement FDK, I followed the SpineFixationFDK example. However, I am getting an error, “muscles are not loaded due to over constrained mechanical system”. Although, I undertand from the error message that reactions take over the function of the muscles leading to no activation, I could not find a solution. Can you help me on this please?
