Muscle Data
Hallo Everybody,
I want to use the calculated muscle forces from Anybody to load my FEM
Model in Ansys. As I already know there is now interface to transfer
the data, so I have to do it manuel. But where can I find the
geometrical parameters of the muscle, e.g. insertion coordinates and
angle of muscles in the different time steps during movement?
I only know that you used the ISB coordinate system…
What are the main sizes of the femur used in the model?
What is the total body weigth/mass of the gait3D model (in the file
AnyMAN I found 64,9kg - but isn’t that very low?) and for the Free
posturemove model?
Thanks and best regards
Thomas
Hi Thomas
There is actually an interface from AnyBody to ANSYS, for details about this
please see message #1413 from 03/08/2007, this message explains more about
this.
There will also be a webcast 5/12 about this subject, please see
http://www.anybodytech.com/633.0.html#c669
If you prefer to do this “manually” I will try to list the things to be
done, in order to read out the variables you will need:
Each muscle has a an insertation and origin point, the “r” values of these
nodes are their position in global coordinates it is updated for each
timestep
So a variable like for example:
Main.Model.HumanModel.Right.Leg.Seg.Thigh.GastrocnemiusNode.r’
gives the global position of this node. If you would like to have it in the
coordinate system of the thigh the variable is :
Main.Model.HumanModel.Right.Leg.Seg.Thigh.GastrocnemiusNode.sRel’ (this
number will not change in time)
In the definition of each of the muscles you will find a variable reference
variables like Org, Via and Ins these are references to the origin, via and
insertation nodes used by this muscle. So instead of the variables above
you could also get acces to the positions of these node by writing
Main.Model.HumanModel.Right.Leg.Mus.BicepsFemorisCaputBreve.Org.r or
Main.Model.HumanModel.Right.Leg.Mus.BicepsFemorisCaputBreve.Org.sRel;
I would recommend creating and AnyOutPutfile and list these variables there,
then will be added as output.
Similarly you can also have the muscles forces added in this output file.
The muscle angles you will not be able to get out as a direct output, these
has to be calculated based on the location of the origin, via and
insertation points.
The sizes of the UNSCALED bones can always be found in the file like
/leg3d/StandardParamters.any all body parts has such a file. If the bone is
scaled these numbers are to be found in file like AnyMan.any of the Gait3D
model.
Concerning the coordinate system of the bones in the leg it is true that
they follow ISB, If you create the line
AnyDrawRefFrame drw={};
In the root folder of for example the Thigh segment, it will display the
location of the coordinate system.
The mass of the subject in the Gait3D model is rather low, but it is
according to the subject where the data originates from.
So it is possible to get the output you need out from the model, but it
requires that you manually create an output file for this.
I hope this helps you move on, otherwise please write again
Of knox40
Sent: 21 November 2007 11:06
Subject: [AnyScript] Muscle Data
Hallo Everybody,
posturemove model?
Thomas
Hi Søren,
thank you for your answer.
So I will do it by writing an AnyOutputFile.
As I found no example how to record to AnyOutputFile, can you give
me an short instruction how to record data to AnyOutputFile. Must I
do first a KinematicMeasure and record it to this File?
Finally I need the muscle angles in the femur coordinate system
(sRel)but you said it isn’t possible to record the vector of origin-
insertion during time. So I can only record in global coordinate
system where the femur also changes position and angle during time?
I think this will make it somewhat more complicated as I must do
twice a calculation of rotation and translation in each time step
(to get the femur coordinate system and to get the muscle angle).
There is no easier way to get this data?
Thomas
wrote:
> Hi Thomas
about this
more about
> this.
to be
of these
each
> timestep
it in the
(this
reference
origin, via and
variables above
or
variables there,
output file.
output, these
> insertation points.
like
the bone is
the Gait3D
> model.
true that
display the
is
but it
> Best regards
> Søren
> _____
On Behalf
> Of knox40
> Hallo Everybody,
FEM
transfer
and
file
> posturemove model?
> Thomas
Hi Thomas
The AnyOutputFile object will create a text file with the output from the
variables listed in the object, so it may look like:
AnyOutputFile Output ={
   FileName ="Data.txt";
   //muscle insertation points in global coordinates
   AnyVec3 MuscleInsertation=.Model.mus1.ins.r;
   AnyVec3 MuscleOrigin=.Model.mus1.org.r;
In this example the variables are just the muscle insertation and origins in
global coordinates, no extra kinematic measures was needed. Typicall this
object is included into the Study folder.
I have created a small example illustrating how to create the output you
request, is has been uploaded to the SmallExamples folder and is named
OutPutFE.any.
It is a model with one segment and two muscles and it produces an output
file which contains a force vector for each muscles. The force vector is
given in the local coordinate system of the segment.
I hope this solves your problem, otherwise please write again.
Of knox40
Sent: 27 November 2007 15:48
Subject: [AnyScript] Re: Muscle Data
Hi Søren,
Thomas
wrote:
> Hi Thomas
about this
more about
> this.
> http://www.anybodyt <http://www.anybodytech.com/633.0.html#c669>
to be
of these
each
> timestep
it in the
(this
reference
origin, via and
variables above
or
variables there,
output file.
output, these
> insertation points.
like
the bone is
the Gait3D
> model.
true that
display the
is
but it
> Best regards
> Søren
> _____
On Behalf
> Of knox40
> Hallo Everybody,
FEM
transfer
and
file
> posturemove model?
> Thomas
Hi Søren,
thank you, the small example was very helpfull.
But what if there is a muscle via point, e.g. the Vastus Lateralis.
For example the muscle fibre comes form the upper part of the femur
to another insertion point of the femur. From this insertation point
it goes then to the shank. So on this point there are two muscle
fibres leaving the femur:
one to the upper part of the femur and another one to the shank.
Am I measuring then the resultant force of these two forces on the
femurpoint with this formula:?
AnyForceMomentMeasure VastusLat1Measure ={
     AnyRefNode &ref1=
Main.Model.HumanModel.Right.Leg.Seg.Thigh.VastusLateralisNode;
AnyViaPointMuscle &mus =
Main.Model.HumanModel.Right.Leg.Mus.VastusLateralis;
Thomas Thielen
wrote:
> Hi Thomas
from the
> FileName =“Data.txt”;
origins in
Typicall this
output you
named
> OutPutFE.any.
output
vector is
> Best regards
> _____
On Behalf
> Of knox40
> Hi Søren,
I
origin-
time?
> Best regards,
> Thomas
ps.com,
> “AnyBody Support” <support@>
> wrote:
> > Hi Thomas
details
> about this
> more about
> > this.
things
> to be
values
> of these
> each
> > timestep
have
> it in the
> (this
variable
> reference
> origin, via and
> variables above
writing
> or
> variables there,
> output file.
> output, these
> > insertation points.
> like
> the bone is
> the Gait3D
> > model.
> true that
> display the
it
> is
> but it
> > Best regards
> > Søren
> > _____
ps.com
ps.com]
> On Behalf
> > Of knox40
ps.com
> > Hallo Everybody,
my
> FEM
> transfer
> and
> file
Free
> > posturemove model?
> > Thomas
Hi Thomas
Your script should work ok, it will take into account both parts of the
muscles.
Of knox40
Sent: 04 December 2007 09:12
Hi Søren,
AnyRefNode &ref1=
Thomas Thielen
wrote:
> Hi Thomas
from the
origins in
Typicall this
output you
named
> OutPutFE.any.
output
vector is
> Best regards
> _____
On Behalf
> Of knox40
> Hi Søren,
I
origin-
time?
> Best regards,
> Thomas
ps.com,
> wrote:
> > Hi Thomas
details
> about this
> more about
> > this.
<http://www.anybodytech.com/633.0.html#c669> ech.com/633.0.html#c669>
things
> to be
values
> of these
> each
> > timestep
have
> it in the
> (this
variable
> reference
> origin, via and
> variables above
writing
> or
> variables there,
> output file.
> output, these
> > insertation points.
> like
> the bone is
> the Gait3D
> > model.
> true that
> display the
it
> is
> but it
> > Best regards
> > Søren
> > _____
ps.com
ps.com]
> On Behalf
> > Of knox40
ps.com
> > Hallo Everybody,
my
> FEM
> transfer
> and
> file
Free
> > posturemove model?
> > Thomas
This is a bit of an old thread, but I have a similar question and I am not sure
the solution
was ever fully resolved.
I would like to extract the [x,y,z] force vector that are applied at each
segment node for a
particular via point muscle. To make this generic, lets assume the muscle has 3
via points:
an insertion, viapoint, and origin.
For the specific case where the muscle does not have a via point, the code
block:
AnyForceMomentMeasure someForceMeasure ={
AnyRefNode &ref1=
Segment.SomeInsertionNode; //Or some origin node, but not a via node
Muscle.SomeViaPointMuscle;
works fine, and someForceMeasure.F returns the force I care about in global
coordinates.
I have tested this and seems to work fine. However, if there is a via point,
and I only want
the force applied by the muscle at that via point (and no other points) the code
does not
seem to be applicable (as per previous posts, see below). Is my interpretation
correct? If
so, what code block (hopefully very similar to the one above) should I be using
if I do not
want to take into account both parts of the muscle together, but separately? I
would like
something that looks like:
AnyForceMomentMeasure someForceMeasure_ORIGINNODE ={
AnyRefNode &ref1=
AnyForceMomentMeasure someForceMeasure_VIAPOINTNODE ={
AnyRefNode &ref1=
Segment.SomeViaPointNode;
AnyForceMomentMeasure someForceMeasure_INSERTIONNODE ={
AnyRefNode &ref1=
Thank you in advance.
-David
> Hi Thomas
> muscles.
> Best regards
> Søren
> _____
> Of knox40
> Hi Søren,
> AnyRefNode &ref1=
> Best regards,
> Thomas Thielen
> wrote:
> > Hi Thomas
> from the
> origins in
> Typicall this
> output you
> named
> > OutPutFE.any.
> output
> vector is
> > Best regards
> > _____
> On Behalf
> > Of knox40
> > Hi Søren,
> I
> origin-
> time?
> > Best regards,
> > Thomas
> ps.com,
> > wrote:
> > > Hi Thomas
> details
> > about this
> > more about
> > > this.
> things
> > to be
> values
> > of these
> > each
> > > timestep
> have
> > it in the
> > (this
> variable
> > reference
> > origin, via and
> > variables above
> writing
> > or
> > variables there,
> > output file.
> > output, these
> > > insertation points.
> > like
> > the bone is
> > the Gait3D
> > > model.
> > true that
> > display the
> it
> > is
> > but it
> > > Best regards
> > > Søren
> > > _____
> ps.com
> ps.com]
> > On Behalf
> > > Of knox40
> ps.com
> > > Hallo Everybody,
> my
> > FEM
> > transfer
> > and
> > file
> Free
> > > posturemove model?
> > > Thomas
Hi David
If I understand you correctly this problem can be solved just by writing
what you suggest
AnyRefNode &ref1=
This will give you the forces acting in the via point node from this muscle.
It will take into account the muscles parts on both sides of this node, but
maybe this is not what you want.?.
The viapoints acts as needle eyes so the muscle can slide in these points.
I have made an updated version of the OutPutForFE.any in the small examples
folder, so that it includes a viapoint muscle the file name is
OutPutForFEV2.any.
If you look at the results of the viapoint measure Mus3Measure you will see
that initially the force is zero, this is because in the first timestep the
muscle is a 100% straight line so it do not create any force in the viapoint
node. Then gradually as the muscles will bend in this point the force is
growing.
I hope i have not misunderstood your question… :wink:
Of dww805
Sent: 26 March 2008 00:40
sure the solution
segment node for a
has 3 via points:
block:
AnyRefNode &ref1=
coordinates.
and I only want
code does not
interpretation correct? If
using if I do not
I would like
AnyRefNode &ref1=
AnyRefNode &ref1=
AnyRefNode &ref1=
-David
> Hi Thomas
> muscles.
> Best regards
> Søren
> _____
Behalf
> Of knox40
> Hi Søren,
> AnyRefNode &ref1=
> Best regards,
> Thomas Thielen
> wrote:
> > Hi Thomas
> from the
> origins in
> Typicall this
> output you
> named
> > OutPutFE.any.
> output
> vector is
> > Best regards
> > _____
> On Behalf
> > Of knox40
> > Hi Søren,
> I
> origin-
> time?
> > Best regards,
> > Thomas
> ps.com,
> > wrote:
> > > Hi Thomas
> details
> > about this
> > more about
> > > this.
> <http://www.anybodyt <http://www.anybodytech.com/633.0.html#c669>
> things
> > to be
> values
> > of these
> > each
> > > timestep
> have
> > it in the
> > (this
> variable
> > reference
> > origin, via and
> > variables above
> writing
> > or
> > variables there,
> > output file.
> > output, these
> > > insertation points.
> > like
> > the bone is
> > the Gait3D
> > > model.
> > true that
> > display the
> it
> > is
> > but it
> > > Best regards
> > > Søren
> > > _____
> ps.com
> ps.com]
> > On Behalf
> > > Of knox40
> ps.com
> > > Hallo Everybody,
> my
> > FEM
> > transfer
> > and
> > file
> Free
> > > posturemove model?
> > > Thomas
Hi Søren,
Thanks for the quick reply. I think we may be agreeing on the same thing (which
is always
a good thing). The concern I have is that I just want to make sure I am not
double
counting the forces due to the muscle if there is a via point and an insertion
point on the
same segment. For example, if I use the code:
> AnyRefNode &ref1=
> Segment.SomeOriginPointNode;
> AnyRefNode &ref1=
I know that someForceMeasure_ORIGINNODE.F and someForceMeasure_VIAPOINTNODE.F
are related (obviously they are caused by the same muscle), but I want to make
sure that if
I apply those forces to the segment (for example in another application) that
those forces
will not be greater than what is actually being felt by the segment. I should
be able to test
this by writing a force balance equation, but I thought I would check in here
first.
Thanks again,
David
> Hi David
> what you suggest
> AnyRefNode &ref1=
> OutPutForFEV2.any.
> growing.
> Best regards
> _____
> Of dww805
> Hi,
> sure the solution
> segment node for a
> has 3 via points:
> block:
> AnyRefNode &ref1=
> coordinates.
> and I only want
> code does not
> using if I do not
> I would like
> AnyRefNode &ref1=
> AnyRefNode &ref1=
> AnyRefNode &ref1=
> -David
> “AnyBody Support” <support@> wrote:
> > Hi Thomas
> > muscles.
> > Best regards
> > Søren
> > _____
> Behalf
> > Of knox40
> > Hi Søren,
> > AnyRefNode &ref1=
> > Best regards,
> > Thomas Thielen
> > wrote:
> > > Hi Thomas
> > from the
> > origins in
> > Typicall this
> > output you
> > named
> > > OutPutFE.any.
> > output
> > vector is
> > > Best regards
> > > _____
> > On Behalf
> > > Of knox40
> > > Hi Søren,
> > I
> > origin-
> > time?
> > > Best regards,
> > > Thomas
> > ps.com,
> > > wrote:
> > > > Hi Thomas
> > details
> > > about this
> > > more about
> > > > this.
> > things
> > > to be
> > values
> > > of these
> > > each
> > > > timestep
> > have
> > > it in the
> > > (this
> > variable
> > > reference
> > > origin, via and
> > > variables above
> > writing
> > > or
> > > variables there,
> > > output file.
> > > output, these
> > > > insertation points.
> > > like
> > > the bone is
> > > the Gait3D
> > > > model.
> > > true that
> > > display the
> > it
> > > is
> > > but it
> > > > Best regards
> > > > Søren
> > > > _____
> > ps.com
> > ps.com]
> > > On Behalf
> > > > Of knox40
> > ps.com
> > > > Hallo Everybody,
> > my
> > > FEM
> > > transfer
> > > and
> > > file
> > Free
> > > > posturemove model?
> > > > Thomas
In AnyForceMomentMeasure only forces that are applied directly to the
reference frame (AnyRefNode in this case) will be included. So it’s
ok, you won’t measure two times the same force and there are no
double counting. It’s all good.
Sylvain, AnyBody Support.
— In anyscript@yahoogroups.com, “dww805” <dwwagner@…> wrote:
> Hi Søren,
thing (which is always
I am not double
an insertion point on the
> > AnyRefNode &ref1=
> > AnyRefNode &ref1=
want to make sure that if
application) that those forces
segment. I should be able to test
check in here first.
> Thanks again,
> David
wrote:
> > Hi David
writing
> > what you suggest
> > AnyRefNode &ref1=
this muscle.
node, but
these points.
small examples
> > OutPutForFEV2.any.
you will see
timestep the
the viapoint
force is
> > growing.
> > Best regards
> > _____
> > Of dww805
> > Hi,
I am not
> > sure the solution
at each
> > segment node for a
the muscle
> > has 3 via points:
the code
> > block:
> > AnyRefNode &ref1=
node
in global
> > coordinates.
via point,
> > and I only want
points) the
> > code does not
should I be
> > using if I do not
separately?
> > I would like
> > AnyRefNode &ref1=
node
> > AnyRefNode &ref1=
> > AnyRefNode &ref1=
> > -David
ps.com,
> > > Hi Thomas
parts of the
> > > muscles.
> > > Best regards
> > > Søren
> > > _____
ps.com
ps.com] On
> > Behalf
> > > Of knox40
ps.com
> > > Hi Søren,
Lateralis.
femur
point
muscle
the
> > > AnyRefNode &ref1=
> > > Best regards,
> > > Thomas Thielen
ps.com,
> > > wrote:
> > > > Hi Thomas
output
> > > from the
and
> > > origins in
> > > Typicall this
> > > output you
is
> > > named
> > > > OutPutFE.any.
produces an
> > > output
force
> > > vector is
again.
> > > > Best regards
> > > > _____
> > > On Behalf
> > > > Of knox40
ps.com
> > > > Hi Søren,
give
Must
> > > I
system
> > > origin-
coordinate
> > > time?
do
step
angle).
> > > > Best regards,
> > > > Thomas
40yahoogroups.com>
> > > ps.com,
> > > > wrote:
> > > > > Hi Thomas
> > > details
> > > > about this
explains
> > > > more about
> > > > > this.
please see
> > > things
> > > > to be
> > > values
> > > > of these
updated for
> > > > each
> > > > > timestep
to
> > > have
> > > > it in the
> > > > (this
> > > variable
> > > > reference
> > > > origin, via and
> > > > variables above
> > > writing
> > > > or
> > > > variables there,
this
> > > > output file.
direct
> > > > output, these
via and
> > > > > insertation points.
file
> > > > like
file. If
> > > > the bone is
AnyMan.any of
> > > > the Gait3D
> > > > > model.
is
> > > > true that
will
> > > > display the
but
> > > it
> > > > is
model,
> > > > but it
> > > > > Best regards
> > > > > Søren
> > > > > _____
40yahoogroups.com>
> > > ps.com
40yahoogroups.com>
> > > ps.com]
> > > > On Behalf
> > > > > Of knox40
40yahoogroups.com>
> > > ps.com
> > > > > Hallo Everybody,
load
> > > my
> > > > FEM
> > > > transfer
the
coordinates
> > > > and
movement?
the
> > > > file
the
> > > Free
> > > > > posturemove model?
> > > > > Thomas
