Hi Prabhav,
Just a brief comment.
Actually, you can be (almost) sure that not all muscles reach an activity of
1.0 simultaneously. For a certain loading situation, the muscles are needed
to various extend; even some are not needed at all, they will end with zero
activity, because they do not help carrying the load at all.
Using the “Min Max Muscle Activity” criterion, which is default in
AnyBodyStudy, you do however obtain that all muscle work together optimally
in the sense that the maximal activity cannot be lowered. This postpone the
point were any of the muscles reach activity of 1.0 as far as possible (i.e.
to as high load as possible) and it also implies that several muscles
(typically) reach 1.0 at the same time because to collaborate “optimally”.
Good luck with your investigation!
/Michael
Michael Damsgaard, AnyBody Support
<http://www.anybodytech.com> www.anybodytech.com
Of Prabhav Saraswat
Sent: Friday, March 14, 2008 16:51
Subject: Re: [AnyScript] Muscle Excitation
Hi Michael,
Thats exactly what I was looking for. I am only
interested in maximal joint force all muscles spanning the joint can
produce. The method you described should solve the problem for me. i
will have only flexion/extension moment in the experimental set-up. So
there should be only one dof for the model. My only concern is that
all the muscle may not reach maximal activation together. I will keep
you posted on what i get out of the model.
Thanks for the quick reply.
Prabhav
On Mar 14, 2008, at 2:38 AM, AnyBody Support wrote:
> Hello Prabhaw,
> AnyBody cannot do forward dynamics - sorry. But if you really want
> to do an
> isometric task, i.e. fixed rotation of the segment, then it is not a
> forward
> dynamics problem. You know the motion (or rather the position),
> which is the
> same for all times.
> As I read your email, you want to find the maximal joint moment the
> muscle
> can produce. Is this right?
> I that case, you can apply an external force to the leg that produce
> the
> wanted joint moment, e.g. you can apply an AnyForce to the joint
> itself
> (e.g. knee rotation would imply to apply a knee moment). If you then
> increase this force (moment), e.g. as a function over time, you can
> identify
> the point when the muscle activity becomes 1. This point is, in a
> modeling
> sense, the maximal capability of the body. At this point you can
> read out
> the value of the external load.
> If you are looking to find other joint reactions, i.e., the constraint
> reaction forces in the joint, then these will depend on the external
> force
> you apply. But this is not your concern - is it?
> Multi-degree of freedom joints and multi-articular muscles may make
> the
> picture a bit more complicated. There are many parameters that may
> affect
> the result you get, so the actual setup you make (posture and external
> constraints supporting the body) are important; as they would be in a
> laboratory experiment.
> Also consider gravitational forces (not easy to get rid of in the
> laboratory, but in AnyBody you can;-).
> I hope this helps a bit.
> Best regards,
> Michael
> <http://www.anybodyt <http://www.anybodytech.com> ech.com>
www.anybodytech.com
> _____
> On Behalf
> Of Prabhav Saraswat
> Sent: Wednesday, March 12, 2008 19:40
> Subject: [AnyScript] Muscle Excitation
> Hi,
> I want to validate a model by calculating joint forces by maximally
> exciting muscles spanning the joint. Is it possible to do this in
> Anybody?
> This will be an isometric task, so segment rotation is zero. Can I
> somehow
> drive all msucles to their maximal activity and calculate joint
> reaction
> force due to muscles? It seems like a forward dynamics problem, is
> there a
> workaround for such problem in Anybody?
> thanks for your help
> prabhav
