Muscle Force Optimization
Dear Support,
I am working to alter the cross-sectional area of the paraspinal
muscles to reflect the iatrogenic injury that occurs in vivo during
surgery. I am trying to show there is a change in the muscle force
activation pattern and capacity before and after the surgery. I am
having a difficult time showing a change due to the optimization that
is used to solve the system.
Can you give me any advice on how to best measure the difference in
force that is generated in these muscles? Thank you.
Lacey Bresnahan
Rush University Medical Center
Chicago IL
Hej Lacey,
This is actually not an easy question to answer.
I guess that you would try to mimic some clinical observations. Could
you explain to us, what kind of observations you would like to mimic?
After that you probably have some kind of hypothesis of what the
mechanism could be. From your mail I can understand that you have
changed the cross-sectional area of the muscles or in other words you
make the muscle weaker. Basically you assume that due to the injury
muscle atrophy takes place in some muscles and afterwards you try to see
if that changes the muscle activation for a certain kind of
movement/posture.
I you then don’t see a difference does not necessarily means that the
optimization procedure is wrong. It also could mean that the
hypothetical mechanism isn’t correct.
There might be some other ways of simulating different mechanisms. But I
think that I need some more information about exactly what you would
like to do.
Regards, Mark
Mark de Zee, Ph.D., Research Associate Professor
Aalborg University, Department of Health Science and Technology
Center for Sensory-Motor Interaction (SMI)
lebresnahan wrote:
> Dear Support,
> Lacey Bresnahan
> Chicago IL
Thank you for your response. Your assumptions are correct. I am trying to
simulate clinical variables; such as atropy of muscle due to surgical
intervention that I have been able to measure in vivo.
I am reducing the CSA of the paraspinal muscles that cross or have
adhesion/attachments points at the L3-4 and L4-5 disc space. I am reducing
these muscles by 10, 30 and 70% from their intact state. I am then simulating
40 and 60% of the MVC contraction for the model. I am so far looking at flexion
and torsion.
I measure the muscle force and the point of maximum movement for each individual
facicle in the trunk muscles as well as psoas, quadtratus lumb., internal and
external oblique. I am unsure of the problem because my activation patterns do
no make physiological sence. For example these are the numbers I get (N) for
the LTpt and LTpl over the entire length of the spine (60% MVC)
               IL pl        IL pt    LT pl    LT pt    Multifi         OE
OI Psoas QL
Intact 220.00 175.70 68.80 167.94 201.50 72.30 146.40
790.50 32.82
-10% 203.00 157.56 101.52 206.12 180.40 68.70 137.40
790.50 30.90
-30 169.60 130.67 132.50 234.60 171.30 71.90 145.50
790.50 3.30
-70 102.80 193.60 110.50 213.02 174.52 67.00 157.90
745.71 0.79
I have checked the accuracy of the 30% reduction multiple times and it appears
correct. I have reviewed what you presented on the cervical model with the
assumption of pain in the sternomastoid m.; and I think I can understand what
you’ve done. The difference is that I am assuming these subjects are absent of
pain and have been fully healed.
Your assumption of what I am looking for is correct. I would like to find a
change in both muscle force and activation between the groups. I have read many
of your papers and presentations. If you have any advice for me I would really
appreciate it. I am in a difficult situation because I don’t know anyone in my
geographical area who has familiarity with the AnyBody system.
Thank you in advance for your time.
Best Regards,
Lacey Bresnahan
Chicago, IL
Sent: Wednesday, January 28, 2009 2:12:31 AM
Subject: Re: [AnyScript] Muscle Force Optimization
Hej Lacey,
movement/posture.
like to do.
Regards, Mark
lebresnahan wrote:
> Dear Support,
> Lacey Bresnahan
> Chicago IL
Hi Lacey,
I think I need some more information here.
Is it a static situation you simulate i.e. standing position? Do you
apply an external force?
You wrote that you got strange muscle activations. Was that with the
muscles in the intact state or only with the weakened muscles?
Maybe it might be worthwhile to upload your model, so that we can have a
look at it.
Regards, Mark
> to simulate clinical variables; such as atropy of muscle due to
> surgical intervention that I have been able to measure in vivo.
> reducing these muscles by 10, 30 and 70% from their intact state. I am
> then simulating 40 and 60% of the MVC contraction for the model. I am
> so far looking at flexion and torsion.
> individual facicle in the trunk muscles as well as psoas, quadtratus
> lumb., internal and external oblique. I am unsure of the problem
> because my activation patterns do no make physiological sence. For
> example these are the numbers I get (N) for the LTpt and LTpl over the
> IL pl IL pt LT pl LT pt Multifi OE OI Psoas QL
> Intact 220.00 175.70 68.80 167.94 201.50 72.30 146.40 790.50 32.82
> -10% 203.00 157.56 101.52 206.12 180.40 68.70 137.40 790.50 30.90
> -30 169.60 130.67 132.50 234.60 171.30 71.90 145.50 790.50 3.30
> -70 102.80 193.60 110.50 213.02 174.52 67.00 157.90 745.71 0.79
> appears correct. I have reviewed what you presented on the cervical
> model with the assumption of pain in the sternomastoid m.; and I think
> I can understand what you’ve done. The difference is that I am
> assuming these subjects are absent of pain and have been fully healed.
> find a change in both muscle force and activation between the groups.
> I have read many of your papers and presentations. If you have any
> advice for me I would really appreciate it. I am in a difficult
> situation because I don’t know anyone in my geographical area who has
> Best Regards,
> Lacey Bresnahan
> Chicago, IL
> ________________________________
> From: Mark de Zee <mdz@hst.aau.dk <mailto:mdz%40hst.aau.dk>>
> To: anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com>
> Hej Lacey,
> movement/posture.
> like to do.
> Regards, Mark
> lebresnahan wrote:
> > Dear Support,
> > Lacey Bresnahan
> > Chicago IL
Hi Mark,
I am on vacation right now, but will be back on Wednesday February 4. I will
review the model in detail and get back to you. How do I upload the model? I
have made several modifications, so would it be best to zip the entire
Repository so you can open and run it from there?
I very much appreciate your assistance. Thank you again for your time.
Best Regards,
Lacey Bresnahan
Sent: Thursday, January 29, 2009 3:21:49 PM
Hi Lacey,
look at it.
Regards, Mark
> adhesion/attachment s points at the L3-4 and L4-5 disc space. I am
> -70 102…80 193.60 110.50 213.02 174.52 67.00 157.90 745.71 0.79
> Best Regards,
> Lacey Bresnahan
> Chicago, IL
> ____________ _________ _________ __
> From: Mark de Zee <mdz@hst…aau. dk <mailto:mdz% 40hst.aau. dk>>
> To: anyscript@yahoogrou ps.com <mailto:anyscript% 40yahoogroups. com>
> Hej Lacey,
> movement/posture.
> like to do.
> Regards, Mark
> lebresnahan wrote:
> > Dear Support,
> > Lacey Bresnahan
> > Chicago IL
