Hello to everybody,
I have a simple question.
Is it possible to get the direction of muscle forces in deformed and
undeformed configuration?
with best regards.
Natiq
Hello to everybody,
with best regards.
Natiq
Hi Natiq
I am not sure, i fully understand the question, what do you mean by deform
and un deformed configuration?
It is possible to use the AnyForceMomentMeasure to find the direction and
magnitude of a muscles force where it attaches to the bone.
In the file section of this group there is a small example of this issue.
Please see the file SmallExamples/OutputForFE.any (or something very
similar ;-)), it should explain among other things how this is done.
Of natiqpervaiz
Sent: 22 February 2008 11:21
Subject: [AnyScript] Muscle forces
Hello to everybody,
with best regards.
Natiq
Thanks for the reply from my previous post as to why the inverse
dynamics did not work. The model works fine now.
However, I have one problem regarding the muscle forces calculated.
Only the muscles which are in contraction appear to exert any force,
with all other muscles remaining passive. For example, the gluteus
maximus is expected to be active, but is not. I wondered - is this
down to poor muscle definition or other factors of the model (e.g.
moment of inertia’s are set to zero). Although the model only performs
a simple motion, I think the extending muscles should still have some
force (similar to the arm model in the tutorial). Also, the calculation
of the muscle length appears to change when all muscles are modelled
together, compared to when they are modelled individually, even though
the same motion is performed.
I have uploaded the model (HipJoint) and would be grateful of any
advice you may be able to provide.
Many Thanks
I think the first reason why you don’t get reasonable activations is because
the units in your model are not coherent. AnyBody don’t work with a specific
unit system, however the system used have to be coherent. We usually use the
SI units. In your model the forces are still in N and the gravity in m.s-2
as usual but the segments dimensions are in centimetres instead of meters as
they should.
So I think the first step is to adjust the units in a coherent system.
Also it would be better to give some moment of inertia to the bones.
About the muscle length you are right there is a small bug but it is
actually of no importance for the results. The output variable Lmt is the
length of the total muscle-tendon unit and Lm is the length of the
contractile element only. In the case of the simple muscle model those two
variables have the same value because the muscle is only a contractile
element. The bug is the following: sometimes Lm returns the value of another
muscle of the model, but Lmt is always correct and is the one you should be
looking at.
Notice that this happens only with the simple muscle model where neither Lm
nor Lmt are used for other calculations, therefore there is no impact on the
muscle forces.
Sylvain, AnyBody Support
Of dc_pete
Sent: 15. januar 2009 16:01
Subject: [AnyScript] Muscle Forces
Many Thanks
Thanks for the advice, much appreciated.
— In anyscript@yahoogroups.com, AnyScript Support
<anyscriptsup@…> wrote:
> Hi,
is because
specific
usually use the
in m.s-2
meters as
> they should.
system.
is the
those two
contractile
of another
should be
> looking at.
neither Lm
impact on the
> muscle forces.
> Best regards,
> _____
On Behalf
> Of dc_pete
> Hello,
force,
performs
some
calculation
modelled
though
> Many Thanks
so far I’ve used the simple muscle model (BodyModel) to calculate the
muscle forces and use them in FEM software. Therefore I’ve used the Fm
value as it represents the total muscle force.
But if I use the MuscleModel3E what is my total muscle force which I
have to consider on the bone in FEM?
Fm is for the contractile element, Fp for the passive force and Ft the
tendon force.
Do I have to sum up this three values to become the total muscle force?
Thank you.
Thomas
Hi Thomas
When using the three element muscles model, then simply use the tendon force
Ft, as the input for the FEM model, this is the force the acting on the
bone.
Of knox40
Sent: 29 January 2009 09:48
tendon force.
Thank you.
Thomas
