Muscle recruitment solver problem
I tried to use the model to perform badminton serve
I used Vicon MOCAP system to capture the motion…
and input C3D file to drive the model
Now… kinematics analysis can be done.
But I add the simple muscle into the model and
tried to do inverse dynamics analysis…
It can not work…
And I got a message:
“Muscle recruitment solver : solver aborted due to singular KKT matrix”
I don’t know what’s wrong and how to solve it…
Please give me some information
Thank you
Best Regards
Kunag-Wei Lin
National Taiwan Sport University
Hi Kunag-Wei Lin,
Once you have the kinematics running, the biggest problem is probably solved!
The Error message
typically indicates that some degrees of freedom are not carried. The reason could be missing muscles for a certain motion, missing reactions in a joint or to ground.
What model are you using? did you change something to the Body?
Amir
Thank you Amir…
I solved the problem…
I forgot to use the “Hook”
Now it works…
Kuang-Wei Lin
