Hello Pete,
Welcome to the group!
Here is a section from the muscle tutorial describing the properties of the
AnyViaPointmuscles:
Via point muscles pass through a set of at least two points on their way
from origin to insertion. Each of the
via points must be attached to a segment or the global reference frame of
the model. The first and the last
of the point sequence are special because the muscle is rigidly fixed to
them and hence transfers forces in
its local longitudinal direction to them. Conversely, the muscle passes
through the interior via points like a
thread through the eye of a needle. This means that the muscle transfers
only forces to interior via points
along a line that bisects the angle formed by the muscle on the two sides of
the via point.
In fact the AnyShortestPathMuscles work pretty much the same. Once in
contact they transfer the forces in the same manner as through ViaPoints.
I hope this helps, please ask again if not.
Sebastian
Of dc_pete
Sent: 11. november 2008 16:33
Subject: [AnyScript] Muscle Wrapping
Hello, I am currently studying a PhD in medical engineering at the
Centre for Medial Engineering and Technology at the University of
Hull, United Kingdom, and using AnyBody to model the biomechanics of
the juvenile pelvis.
I am currently constructing a biomechanical model of the hip joint
within AnyBody. I have appled muscle wrapping through
AnyShortestPathMuscle to accurately model the musculoskeletal
features. However, this is proving challenging due to complex
geometry and muscle interaction.
Therefore, I am investigating using AnyViaPointMuscle and specifying
via points (rather than wrapping to bone). However, I am unsure if
AnyViaPointMuscles wrap around the via points (similar to
AnyShortestPathMuscle wrapping around bone) or if the muscle is split
into different segments (visually the graphics display the muscle in
two different strands). I would be grateful of any information
regarding this topic.
Many Thanks
Pete Watson
