I am still try to track “my” BikeModel with measure dates.
My big problem is, my model is always statically/ kinematically
indeterminate. There are more reactions then rigid body degrees of
freedom! That happens, because I added some additional constrains
(AnyKinEqInterPolDriver) to the “original” model.
I tried to reduce constrains by applying cylindrical on place of
revolute joints, so I could save one constrain in z- direction each.
But there are unfortunately some forces in z- direction, so this is
not a good solution!
But I recognised that your model from repository has some reaction
forces ( 3. List of reaction forces) which are not active, e.g.
….CrankRotation.Reaction(0 active of 1 reaction)!!
Why does the driver still work?
Are there some additional tricks, which I should know?
Or do you have an advise how I could solve my statically/
kinematically indeterminate problem?
— In anyscript@yahoogroups.com, “jrgleemann” <lee5@b…> wrote:
> Hi John
When you add a driver to the model it will by default carry the load
of the DOF’s of the particular driver. To avoid this the you should
type
Reaction.Type={0};
inside the driver definition
by default it will have the following setting
Reaction.Type={1};
which means the driver will carry the load, it’s an engine
The crank rotation driver has a Reaction.Type={0} this is why it is
listed as not active. If the reaction.type of this driver had been
one it would take away the crank moment from the legs.
In general when you add more constraints to this model you should
remove the same quantity. I hope the Reaction.Type issue will do this
for you.
I hope this answers your questions, otherwise please feel free to ask
again.
