hi sir,
im in research with anybody tech for reducing factor of neck injury while car crash. for that im trying to design car seat. i need technical information and how i can use anybody tech effectly to achieve the target , the methodology im seeking,both car seat model , and musculo skeletal models available in anybody motion tech?kindly reply me back.
firstly you should be aware that the AMS is not intended for use in crash simulations. The underlying assumptions on the muscle recuitement are controlled, skilled motions.
Apart from this a good starting point is the seated human model in the repository, take it and adjust the geometries according to your desired car seat design. The standard human body model with neck should be fine.
Sebastian
