New and a little confused
Hello all,
I’m sorry if this is a dumb question, but I’ve been working the
Mannequin file trying to set up a custom initial position and I’m
stuck. I would like to determine the overall center of mass and moment
of inertia of the body in this initial position. Is there an easy way
to do this? I can’t seem to find this anywhere. I am using the free
posture full body ARep model. Thanks in advance,
Kenton Harris
Hi Kenton
It is a relevant question
You can use the AnyKinCoM object for measuring the center of mass of a
number of segments.
So writing something like this should measure the collective center of mass
for the entire human model
AnyKinCoM CenterOfMass={
AnyFolder &ref=Main.Model.HumanModel ; //or similar….
Unfortunately there in no easy way like for the CoM to get the overall
moment of inertia out, this will have to be done through transformations
written in your script.
Of uvamfd
Sent: 19 March 2008 05:32
Subject: [AnyScript] New and a little confused
Hello all,
Kenton Harris
I’ve implemented the code into the FreePosture.Main file, and the
Center of Mass folder appears in the model tree, but the values are
blank. Help!
Kenton Harris
> Hi Kenton
> number of segments.
of mass
> Best regards
> _____
On Behalf
> Of uvamfd
> Hello all,
> Kenton Harris
Hi Kenton
I can think of two things which could go wrong.
1 the measure did not find any segments listed in the measure
2 the kinematical analysis was not done, so the position of the CoM was not
calculated, it will then have a zero value if you click on the
CenterOfMass.Pos item in the ModelTree.
if you look at the CoM in the ModelTree you should be able to see a object
names SegNames this is a list of the segments included in the measure. If
this is empty it is because no segments was included into the measure.
If this do not provide any help, please make a copy of the script used to
create the AnyKinCoM measure so something like
And give a detailed description of the analysis steps you did, and which
results you got.
Of uvamfd
Sent: 24 March 2008 22:16
Subject: [AnyScript] Re: New and a little confused
blank. Help!
Kenton Harris
> Hi Kenton
> number of segments.
of mass
> Best regards
> _____
On Behalf
> Of uvamfd
> Hello all,
> Kenton Harris
