I’m studying the new version of the TLEM model (v1.1) in the AMMR 1.6. I noticed that some of the muscle origins/insertions from the cadaver dataset have been modified. Take for example the insertion of the “adductor magnus mid” nodes, which were moved 1 cm in the Z direction. If you look at these nodes on the model, they no longer lie one its insertion line.
Some of these modifications are explained in the code, but some others are not explained, which is problematic because we do not know whether these modifications were wanted or not.
I’ve been told that the femur and tibia bone do not correspond to the TLEM cadaver dataset v. 1.1, and that they were fitted using a fitting between the STL geometries an a point cloud of muscle attachment points. However, if we look at the result, some of the nodes are not located at the right place on the bone.
I also know that this going to be fixed in the next dataset (2.0), since the cadaver bones will be included. Where do you plan to release the new dataset ? If it is relatively soon, I may not want to work too hard on the actual TLEM model and wait the next release.
Thank you.
Pierre
