I have create a orthosis with AnyExp4SOLIDWORKS, and I am trying to give it movement with three nodes, I can load my model, but when I start the Study.Kinematics, it falls and it shows this message: "No kinematic constraints (AnyKinEq objects) found in the study. ERROR(OBJ.MCH.KIN3) : D:/PAU/O..V/D..a/E..V/S..S/S2/A..y/S..y/M..l/OrtMono.main.any(91) : Study.InitialConditions : Kinematic analysis failed in time step 0 : Velocity analysis is not completed".
To give movement it I have created three nodes with "AnyRefNode", to conect nodes with the movement files I have used "AnyKinLinear", and finally I have charged movement files with "AnyKinEqInterPolDriver".
I used this funcions at the past to give movement with Standing Model and it worked without problems, I do not understand which it is the problem.
I have attached the model if anybody could help me to find the mistake because the model does not work.
I have just put the solidworks model and the drivers inside a folder called "Model" and it continuous the same problem: "No kinematic constraints (AnyKinEq objects) found in the study."
You have not added the line below in the AnyBodyStudy like it wrote earlier.
AnyFolder &ref=.Model;
If you do this model runs.
This lines allows the study to know that it should do the analysis on the "Model" folder. If this is not specified the study is "empty" it does not have anything to work on.
