Hi everyone,
How should I orient the reference frame of a created node on the body model with that of the global reference frame.
Thanks a lot for your help :).
Hi Naga,
In order to create a node (Node_GlobalRF) on a given segment (Seg_1) with the same orientation as the global ref frame use the following:
AnySeg Seg_1 = {
AnyMat33 AOffset = Seg_1.Axes0;
AnyVec3 rOffset = Seg_1.r0;
AnyRefNode Node_GlobalRF ={
sRel = -.rOffset*.AOffset;
ARel = .AOffset';
This particular code places the node at the global origin, adjust if necessary.
Christine
