Objective functions
I have two questions:
  1. Is there any other objective functions I can use in AnyBody instead
    of using Minimum maximum relative muscle load?
  2. I would like to use EMG measurement data to verify my muscle
    estimation from AnyBody. What would you suggest me to do if those two
    don’t match well? Can I change the objection functions in AnyBody and
    try which one is close to the EMG measurement?
Thanks in advance for your answer.
Mark
Hi Mark,
> AnyBody instead
Please check out the “Study of studies” tutorial here:
http://www.anybodytech.com/512.0.html
> if those two
> in AnyBody and
You have some control over the recruitment criterion as described in
the tutorial mentioned above. But most reasonable recruitment
criteria are somewhat related, so if the difference is very large,
then there is probably something else wrong with the model.
If you post a description of what the model does, then we can
probably give some hints.
John,
AnyBody Support
