I want to obtain the smooth model of L5 lumbar vertebra from the tutorial, Where can I get it?
If you double click on the vertebra in the model view, the system will expand to the drawing object in the model tree for the object you double clicked on. In the model tree, if you right click, you will see the option to Export surface. You can then export the surface as an STL file.
Additionally to Dave's message, please choose export in "local ref. frame"
