On/Off-differentiation in Macro
Dear AnyBody,
I have a question concerning the macro-function.
I have found, that using a command like: load “Demo.Arm2D.any” -def N_STEP=“10” enables the user to define variables in the macro.
In my case, not only variables have to be defined. I have the following differentiation in my file:
#define MOTION_CAPTURE ON
#if MOTION_CAPTURE == ON
#else
#endif
Now I want to declare in the macro, whether MOTION_CAPTURE is ON or OFF. My question is: How can this be done?
Thank you very much,
Kilian
Hi Kilian,
ON/OFF are just synonyms for 1/0 (used for the code readability)
On:
 load "Demo.Arm2D.any" -def N_STEP="10" -def MOTION_CAPTURE="1"
Off:
 load "Demo.Arm2D.any" -def N_STEP="10" -def MOTION_CAPTURE="0"
The definition of a string define varies a little (if you need one):
load "Demo.Arm2D.any" -def N_STEP="10" -def SOMESTRING=---"\"TEST\""
