Dear all,
I tried to output the displacement of some bony landmarks of the GaitFullBody model of the AMMR v1.6. But the results are confusing me.
For example in the case of the medial femur epicondyle {0.0768,-0.405,-0.0321} with respect to the global reference frame, as given in the file “ModelParameters.any”.
I used the following code in the main:
AnyOutputFile FemurLandmarks= {
FileName = “FemurLandmarks.txt”;
NumberFormat = {
Digits = 15;
Width = 22;
Style = ScientificNumber;
SepSign = " ";
LineSepSign = “”;
Header = {
TitleSectionOnOff = Off;
ConstSectionOnOff = Off;
VarSectionOnOff = Off;
ColumnNamesOnOff = On;
LinePrefix = “”;
AnyVector EpicondylusFemorisLateralis =.BodyModel.Right.Leg.Seg.Thigh.EpicondylusFemorisLateralis.r;
AnyVector EpicondylusFemorisMedialis =.BodyModel.Right.Leg.Seg.Thigh.EpicondylusFemorisMedialis.r;
The values of the displacement of the medial femur epicondyle at the beginning of the calculation {0.113, 0.415, -0.27} are different from the value {0.0768,-0.405,-0.0321} ; Why?
Thanks in advance for your help!
Cheers,
Arnaud
