Output files: axes and muscle points
I am outputting segment axes and muscle points from my model and
would like to confirm their format.
  1. Am I correct to assume that the locations of the axes are with
    respect to the global coordinate system?
  2. Are the outputted axes information the direction cosines between
    the global and the local (segment) coordinate systems? Thus, could
    the outputted axes information be formatted as:
    [Axes[0][0], Axes[0][1], Axes[0][2];
    Axes[1][0], Axes[1][1], Axes[1][2];
    Axes[2][0], Axes[2][1], Axes[2][2]]
which would correspond to the rotation matrix:
[cosXx, cosXy, cosXz;
 cosYx, cosYy, cosYz;
 cosZx, coxZy, cosZz]
(where cosXy would be the direction cosine between the global x-axis
(X…capital letter) and the local y-axis (y…lowercase letter))?
  1. Are the muscle point locations output in the segment (local)
    coordinate sytstems to which they are associated with in the .any
    files?
Thanks for the help.
Chris
Hi Chris
Here are some answers to your questions.
1: Yes this is correct the “Axes” property always referes to the
global ref system. The “ARel” property on the other hand is wrt. the
local coordinate system.
2: Yes this description seems ok
3: The “sRel” values of a AnyRefNode, which are used by the muscles
are always given in the reference system of the segment they belong
to. If you look at the “r” property of the nodes you will get the
nodes position vector wrt. to the global ref system.
> 1) Am I correct to assume that the locations of the axes are with
> 2) Are the outputted axes information the direction cosines
between
axis
> 3) Are the muscle point locations output in the segment (local)
> files?
> Chris
Søren,
Thanks a lot. I assume you can output all the muscle via points too
(if a muscle has via points), and not just the origin and insertion
points?
What I am really interested in, is the muscle lines of action. For
some muscles in some postures, the line of action from the origin to
the insertion is an acceptable assumption, but for others, which
wrap around objects, the origin-insertion line isn’t quite accurate.
Is there any easy output available for this? If this cannot be done
directly, can you output the points which contact the wrapping
object, so that a line of action from the origin to the wrapping
point can be determined?
Thanks again.
Chris
wrote:
> Hi Chris
the
muscles
belong
> Best regards
with
> between
could
> axis
letter))?
the .any
> > files?
> > Chris
Hi Chris
Yes the viapoints can be outputted just as any other point.
The contact points in the wrapping muscles can not be save in any
way, so this is simply not possible today to get coordinates of
these points out, i am sorry.
Could you explain a little bit more about what to use this for?,
this will help us get an idea on what the user need and possible
improve the next version. We are always open for suggestions on
future facilites.
> Søren,
too
insertion
> points?
to
accurate.
done
> Thanks again.
> Chris
> wrote:
> > Hi Chris
> the
> muscles
> belong
the
> > Best regards
and
> with
> > between
> could
x-
> > axis
> letter))?
(local)
> the .any
> > > files?
> > > Chris
Thanks Søren,
I am interested in the muscle lines of action to use as inputs to a
finite element model of the shoulder. As I mentioned before, the
origin-insertion path works well for some muscles in some postures,
although not so well for others. For example, if the origin-
insertion method is used for the middle deltoid–with the arm in 0
degrees of abduction, flexion, and rotation–the line of action
points superiorly and medially. However, if the most medial muscle
wrap point is used with the muscle origin, the line of action points
almost completely medially. Does this help?
Chris
wrote:
> Hi Chris
> future facilites.
> Best regards
> > Søren,
> too
> insertion
> > points?
For
origin
> to
> accurate.
> done
> > Thanks again.
> > Chris
> > wrote:
> > > Hi Chris
the
wrt.
> > the
> > muscles
> > belong
> the
> > > Best regards
> and
> > with
> > > between
> > could
global
> x-
> > > axis
> > letter))?
> (local)
> > the .any
> > > > files?
> > > > Chris
