I want to export data from AnyChart2D/3D like a 3D graphics.
Is it any way to do it directly? Or simpliest way is export coordinates in txt and then draw graphics from this data?
You can export the AnyChart data as Metafile. The file is a vector graphic that can be opened by graphic editor programs. I think that is what you meant?
This should need less data manipulation than editing again the plots from the text file.
Best regards, Sylvain.
