When the modeling is complete and the kinematics and dynamics analysis is completed,
the muscle forces are output in a table such as CSV or TXT.
How do I write this?
Hi @jiang and welcome to the forum!
To save output from the simulations you can use the AnyOutputFile class.
In the reference manual you can also find a class example on how to set it up.
You find the manual bygoing to Help -> AnyScript Reference.
Bjørn
AnyBody Technology
Thank you for your reply. This problem has been solved.
But now I have another problem.
In the example of the static model of the backpack, when the weight of the backpack is changed, the muscle forces are changed. But in the gait analysis model, after the shoulder load is increased, the muscle force is unchanged, why is this?
