Hello.
I want to perform a very simple parameter study
using “AnyParamStudy1D”. But unlike the situation described in the
tutorial “Defining a parameter study”
(http://www.anybodytech.com/657.0.html) I don’t want the maximum
value of the output vector. I want the whole vector (ie results from
all time steps for all iterations).
— cut from tutorial —
AnyBodyStudy Study = {
AnyOutputFun MaxAct = {
Val = .MaxMuscleActivity;
AnyParamStudy ParamStudy = {
AnyDesMeasure MaxAct = {
Val = max(…Study.MaxAct());
I can’t figure out the correct syntax. Is there a way to do this
without writing out files to the operating system (ie keep it all
within AnyBody)?
/jokke
The AnyDesMeasure need to be a single value, it is not allowed to
assign it a vector. I also tried to make the AnyDesMeasure dependent
on a second variable that would be time but it is not allowed either.
That mean it is not possible to do it directly. I think you have no
other choice than writing output files.
Sylvain, AnyBody Support.
— In anyscript@yahoogroups.com, “joakim_holmberg” <jokke@…> wrote:
> Hello.
from
> within AnyBody)?
> /jokke
