Dear all
I am trying to pass a vector from python to anybody. The vector is a design variable ( so editable) in anybody and the class is a AnyVec3
In python, I am defining and setting it as follows:
DAcro1 = [{-0.014,0,0}]
SetValue('Main.HumanModel.BodyModel.Right.ShoulderArm.ModelParameters.Scapula.DAcro1',DAcro1),
Anybody performs the inverse dynamics analysis but in the end python states the analysis failed.
The logfile provides the following information:
Macro command > classoperation Main.HumanModel.BodyModel.Right.ShoulderArm.ModelParameters.Scapula.DAcro1 "Set Value" --value="{0, -0.014}"
ERROR(SCR.EXP11) : C:\Users\johan\Nextcloud\Johanna\AnyBody.7.3.x\21_01_ammr-master\Body\AAUHuman\ARM\ArmData1.1/ArmModelParameters.any(521) : 'DAcro1' : Incorrectly sized array reinitialization data for 'AnyFloat[3]'
||============================Edit Value==============================
|| DAcro1 = {0.0, 0.0, 0.0}
|| DAcro1 =||====================================================================
||==========================Message Dialog============================
|| Error : Set value is not allowed for given model running state.
|| Press : < OK (Any Key) > : OK
||====================================================================Macro command > operation Main.Study.InverseDynamics
Macro command > run
- InverseDynamics (Operation: Main.Study.InverseDynamics):
0.0) PreOperation (Operation: Main.Study.InverseDynamics.PreOperation):
0.0.0) InitialConditions (Operation: Main.Study.InitialConditions):
0.0.0) ...Design variables have been updated.
0.0.1) ...Load-time positions have been re-established.
0.0.2) ...Kinematic analysis completed.
0.0.3) ...Dependent variables are fully updated.- Inverse dynamic analysis...
- ...Inverse dynamic analysis completed
Total simulation time: 61.541
It seems its setting the wrong values (--value="{0, -0.014}"), however I dont know where it is taken the x-component from as -0.014 is the x-component that I pass. The y- and z components are missing.
I assume there is an error with the brackets?
Would be great if you could illuminate me ![]()
Thank you and best regards
Johanna
