Hi David
Nice little model…
You are right about the acceleration data of the joint, they look rather
strange and not like a sinus shape you would expect from a pendulum.
It looks like that the accelerations has been made linear in sections of
about 0.4 sec or so, I do not think it will be possible to get reasonable
results with this acceleration. I do not think these kinks can come from the
interpolations in AnyBody, it must come from the other simulation tool you
are using.
We have tried to simulate the motion of the pendulum in Excel, and impose
the calculated motion onto the pendulum, this gives zero reaction in the
joint as it should.
The model has been uploaded as PendulumReactionForceV2.zip and it contains a
modified model with two identical pendulums, yours and a new one like yours,
but driven with data from an excel simulation. If you look at the joint
moment you will see that they are zero for the new pendulum driven by the
excel data. The new pendulum is not visible because Jii has been set to
zero, the simulations in excel does not take nonzero inertia into account.
Of dww805
Sent: 29 October 2008 23:37
Subject: [AnyScript] pendulum test case
I am trying out a test case similar to one of the tutorials where data from
an idealized
mocap marker was attached to a pendulum. The tutorial mentions that the data
for the
marker driving the pendulum was created from another source.
I have done the same thing using a separate piece of software. I created an
AnyBody
model in which I am driving the the pin joint of my pendulum with my
outputted angular
data, and I am keeping the Reaction.Type {On}. My hope is that after running
the inverse
dynamics, that reaction would be 0 (or very close).
Unfortunately, when I bring the position data into AnyBody with an
AnyFunInterpol
function, I can’t seem to get reasonable acceleration data to get the
reaction in the joint
motor to go to 0. I have tried downsampling, increasing the number of data
points, and
increasing the order of the bspline. I was about to start playing around
with some
different filters, but thought I would post the question here first.
I have uploaded my model and the data I have been playing around with in the
file section
(PendulumReactionForce.zip). Any help or guidance would be much appreciated.
Thank you in advance,
David
