I have a model to simulate lower extremity bracing in static
condition. Bracing forces and moment are applied on the foot
(GroundJoint) and the bracing posture is given. These information are
determined in the file “Mannequin”. However, when I run the
InverseDynamicAnalysis to calculate muscle forces, the hip always
adduct that makes the final hip angle not in the desired posture. All
the rotation at hip joint are constrained. Is there anything I missed
in the modeling? The model file is uploaded in the folder “braking
problem”. Thanks for your help.
I took a quick look at your model. I don’t see any difference in the
Hip adduction from the SetInitialConditions to the
InverseDynamicAnalysis? You can just change the adduction in the
Mannequin.any file. Maybe I misunderstand?
Christian, AnyBody Support
— In anyscript@yahoogroups.com, “chiayuan_um” <chiayuan_um@…> wrote:
> Hi,
> Regards,
> Mark
Thanks for your answer. I think I didn’t make my question clear.
The posture given in the Mannequin.any file is my target posture. When
I load model in the model view, the posture shows as what we give. For
example, if we look up from the bottom of the chair, two thighs are
parallel with the edges of the seat. However, when I run either
SetInitialConditions or InverseDynamicAnalysis, hip angle changes (two
knees are closer).
I am expecting the muscle force prediction is from the posture I set
in the Mannequin.any. Now, the results seems from the new posture. All
the joint movement at the lower extremity ate constrained. I am
wondering why does the posture change? How can I solve this problem?
Thanks for your time and help.
Mark
> Hi Mark
> Best regards
> — In anyscript@yahoogroups.com, “chiayuan_um” <chiayuan_um@> wrote:
> > Hi,
> > Regards,
> > Mark
The initial positions are the load time postions, these are not
accurate, since the model kinematics have not been solve yet.
When you run a kinematic analysis the load time positons are used as
the initial guess of the segments positons, nothing else. So in
principle these should just be good enough to let the model solve in
the correct way.
In all the repository model the initial positions are calculated
using the joints angles from the mannequin.any file. If you look into
the initialposition.any file you will see a lot of equations. This is
basically a “hardcoded” remake of the real models kinematics. In
previous versions you had to give the rotataion matrix for each
segment. For models like FreePosture the load time positons and the
positions after having solved the kinematics will be almost
identical, because they are driven in the same way. As soons as you
apply any other drivers to the model than this, there will not be a
perfect macth between the positions. This is not a problem as long as
the mannequin values are good enough to make the model assemble
correctly.
So to summarize, it the positions you have after having solved the
kinematics that counts, the intial ones should just be close enough.
Except from that they have no influence on the model.
Søren AnyBody Support
wrote:
> Hi Christian,
When
For
(two
> knees are closer).
All
> Mark
wrote:
> > Hi Mark
the
> > Best regards
wrote:
> > > Hi,
information are
always
posture. All
missed
folder “braking
> > > Regards,
> > > Mark
> Hi Mark
> the correct way.
> correctly.
> Best regards,
> wrote:
> > Hi Christian,
> When
> For
> (two
> > knees are closer).
> All
> > Mark
> wrote:
> > > Hi Mark
> the
> > > Best regards
> wrote:
> > > > Hi,
> information are
> always
> posture. All
> missed
> folder “braking
> > > > Regards,
> > > > Mark
