I tried hard to build my own specific model by using the rbf scaling. However, I found that the RBF scaling actually results in a larger knee contact force. Am I doing anything wrong in the custom scaling? The version of AnyBody I am using is 6.0 and AMMR 1.6
There are a couple of things that come to my mind. LengthMassFat scaling also scales the strength of the muscles. It may make some difference.
But I think the bigger change could come from the moment arms of the muscles that may be different in two models. You can try to identify the muscle that is the largest contributor when you see the large reaction force and maybe you can compare the moment arm of this muscle in the two models. We have an example in the current AMMR to evaluate moment arms. Basically, you need to set a define statement and this will include some additional studies in your model to evaluate moment arms. I am not sure if this example and option will be there in AMMR 1.6, though.
Actually I scale both of the model with LengthMassFat scaling while changing a bit of the code to fit my custom scaling law. I may try and evaluate your advise but i dont think it may be the main reason.
I just realize that I am using the simple muscle model during analysis. How should I change my code such that muscles in my human model are using 3 element hill type model? Thank you.
Thanks for helping. I successfully implemented the Hill-type muscle into my model. However, the second peak force is still 400N higher than the experiment. I have looked into your suggestion but unfortunately I couldn't find any example related in AMMR 1.6. However, I could recognise that the muscle force is much higher in RBF scaling model than the linear one. Also, both scaling method will result in a higher second peak contact force while keeping the first peak force good. Would you able to provide some hints for me to see what may be the reason to cause the result? Thank you.
Between RBF and linear scaling, you would really need to compare muscle moment arms. I think the origin, insertion, and via points for the muscles will scale differently between the two scaling methods and a small change in the moment arm can lead to large change in the muscle force.
Regarding the higher second peak, this can be due to a few reasons. At toe-off, the gastrocnemius probably shares more of the load than it should, resulting in higher knee reaction forces. This can be due to more advantageous moment arm of the gastrocnemius compared to soleus. You can probably fix this by passing them both through a common via-point. Another reason could be the way the muscles are split. Soleus is split into multiple units and this affects how muscles are recruited. See this link. You can either replace the soleus units with a single soleus muscle or you can introduce a normalization factor in each of the muscles. See this previous thread on how to do it.
At this point, I would recommend you consider upgrading and requesting access to the beta version. The beta version of AMS has new features that can make it easier to normalize based on muscle volume.
