Project test
I have AMMR 1.5 and have an AnyGait program through it. Each time I upload my own C3D files and use my own project title, the projct “test” is instead processed and uses default heights and weights. how can I overcome this?
Ammar,
did you click on save project?
if yes, did you get any error message after that?
if you dont type in a project name, or don’t click save, AnyGait will load the last used project (by default that is test).
