I just changed all the markers that were in the BRep to the ARep, and I realize
now why I had done what I did. When I try to run the model and
SetInitialConditions the way I have the markers set up now, the model fails.
However, when I have specific nodes, declared in the BRep, for the Sternum and
ACLatBord (on the scapula), the model compiles. So for example, when I have the
AnyRefNode &Sternum as shown below, the model runs. However when I change that
below to AnySeg &Sternum = Main.MyArm.HumanModel.Trunk.SegmentsThorax.ThoraxSeg;
I can’t get the model to SetInitialConditions.
AnyKinEqSimpleDriver STNDriver = {
AnyKinLinear STN = {
Ref = 0;
AnyRefNode &Sternum =
Main.MyArm.HumanModel.Trunk.SegmentsThorax.ThoraxSeg.STNMarker;
AnyRefFrame &ref1 = Main.MyArm.Markers.p1.Seg;
AnyDrawPLine drw={Thickness=0.0015;RGB={0,0,1};};
//Sternum ={AnyDrawRefFrame drw1={RGB={0,1,0};};};
MeasureOrganizer = {0,2};
DriverPos = {0.0,0};
DriverVel = {0.0,0};
Reaction.Type={Off,Off};
AnyKinEqSimpleDriver RSHODriver = {
AnyKinLinear RSHOMarkerLin = {
//Ref = 0;
ref2={AnyDrawRefFrame drw2 = {ScaleXYZ={0.15,0.15,0.15};RGB={0,1,0};};};
AnyRefNode &ref2 =
Main.MyArm.HumanModel.Right.ShoulderArm.Seg.Scapula.ACLatBord;
AnyRefFrame &ref1 = Main.MyArm.Markers.p5.Seg;
AnyDrawPLine drw = {Thickness=0.0015;RGB={0,0,1};};
MeasureOrganizer = {0};
DriverPos = {0};
DriverVel = {0};
Reaction.Type = {0};
How do I change this to go about it correctly without altering the BRep so that
the model still compiles?
Thanks for your help,
Sarah
-----Original Message-----
> Date: Wed Jun 27 08:18:42 EDT 2007
> From: “AnyBody Support” <support@anybodytech.com>
> Subject: [AnyScript] Re: Increasing DOF in the wheelchair model - continued
> Hi Sarah
> The first error you get means that this muscle is overstretched the
> quick fix to this is to switch to the simple muscle model, by
> shifting the include statement, this i would recommend at this stage
> of the model. Shifting the muscle model may help on the recruiment
> problems, too.
> The second error is a wrapping error; the fix is usually to increase
> the property SPLine.StringMesh for example by 10 or 20.
> I have tried to run your model but i miss some markers you have
> defined in the BRep i think.
> In the MarkerPosOnBody.any file you define the some new markers by
> creating nodes inside markernodes already existing
> So the lines
> // AnyFolder &C7 =
> Main.MyArm.HumanModel.Trunk.SegmentsThorax.ThoraxSeg.C7Marker;
> // C7={
> // AnyRefNode C7 = {
> // sRel = {0,0,0};//{-0.06,0.005,0};//{-0.03,-.028,0.00};
> // AnyDrawNode drw={
> // ScaleXYZ={0.01,.01,.01};
> // RGB={0,0,1};
> Will create a new node “C7” inside the node named “C7Marker” i do
> not really understand the purpose of this.
> I think it would be better to do the following
> AnyFolder &thorax =
> // thorax={
> // AnyRefNode C7Marker = {
> // sRel = x?, y?, z?
> // RGB={0,0,1};
> and then at the same time remove the markers from the bRep.
> This will allow me to run you model without changeing the BRep.
> Best regards
> Søren
> — In anyscript@yahoogroups.com, “Sarah R. Sullivan” <sarsulli@…>
> wrote:
> > Thank you for all your help, Soren! I have slowly made progress
> > increasing the degrees of freedom in the model by driving the
> pelvis
> > and trunk positions with mocap data, however I still have a few
> > questions. First off, let me tell you what I have done so far:
> > - Using trochanter markers, I am able to drive the pelvis in
> the x-
> > (anterior/posterior), y- (inferior/superior), and z-
> (medial/lateral)
> > directions. I drive the right trochanter in the x- and y-
> directions,
> > and the left trochanter in the y- and z- directions. In lieu of
> these
> > drivers, I have taken out the old “SeatHeight” driver.
> > - Using the shoulder markers (lateral border of the AC), I am
> driving
> > the x- direction (sterno-clavicular protraction/retraction) with
> mocap
> > data. To do this I took out the corresponding driver in the
> > “SCDriverRight” and “SCDriverLeft.” I still however, am unable to
> > successfully drive the elevation/depression of the shoulders,
> which I
> > eventually want to be able to do.
> > - I am driving the sternum in the x- and z- directions, the C7
> marker
> > in the z- direction, and the T3 marker in the y- direction. I have
> > removed the “SeatBackDriver,” and the PelvisThoraxLateralBending
> and
> > PelvisThoraxRotation from the “PostureDriver” (I still have the
> > PelvisThoraxExtension being driven by the “PostureDriver”).
> > I can get the model to compile, and SetInitialConditions, however
> the
> > individual is inaccurately tilted to the left (see the two images I
> > have uploaded showing the mocap data at pushrim contact for this
> > particular individual). When I run the KinematicAnalysis I get the
> > following warning at frame 46 (out of 58):
> > WARNING(OBJ.MCH.MUS2) :
> > BRep\Aalborg\Arm3D\Muscle-parameters-shoulder.any(1310) :
> > ‘trapezius_scapular_part_4’ : Muscle without strength : The
> muscle
> > has been stretched too much
> > Followed by the error in frame 55:
> > ERROR : BRep\Aalborg\Arm3D\Muscle.any(36) :
> > biceps_brachii_caput_breve : Unexpected exception in the
> library
> > OOSol : OOSol exception : General factorization exception :
> Negative
> > or zero pivot
> > At which point the analysis ends.
> > I would still like to completely free up the posture driver and
> have
> > something drive the thorax flexion/extension (I am still unsure
> as
> > to how to potentially re-adjust the STN, C7, and T3 markers to do
> > this). And I want to allow elevation/depression of the shoulders
> by
> > taking out the driver that holds this constant (in the
> SCDriverRight
> > and –Left), by using the shoulder markers to do this.
> > I have uploaded the current model (SarahArmModel - Muscles -
> > IncreasingDOF_6-22-07.zip), in which there are the aforementioned
> > pictures (PASaggital.jpeg and PAFrontal.bmp) for reference. If you
> > could take a look at it and give me any suggestions you may have, I
> > would really appreciate it!
> > As always, thank you for your help,
> > Sarah
> > PS – At this point, I’m not too concerned because I think when the
> > kinematics are correct it may help, but I am currently unable to
> get
> > the InverseDynamicAnalysis to run at all due to the following
> problem:
> > ERROR(OBJ1) : ArmModel.main.any(61) : ‘MyStudy’ : Muscle
> > recruitment analysis failed, simplex solver reports that solution
> does
> > not satisfy all constraints.
> > Like I said, I think that with correct kinematics this may change,
> but
> > I figured I would let you know about my problems with this
> analysis.
