There is a question confused me about the calculation of distance between hip joint center of acetabular cup and femoral head by FDK. A 0.2mm radial clearance was adopted to my THA prosthesis model. It means that if the cup and head contact, there should be at least 0.1mm translation between hip joint center of cup and head. However, I found that the results from Anybody were all lower than 0.1mm. Should I add the radial clearance to the results calculated by the software?
here is my script to calculate the distance
AnyKinLinear HipHJC={
AnyRefNode &PelvisHJC= Main.HumanModel.BodyModel.Trunk.SegmentsLumbar.PelvisSeg.Left.HipJoint;
AnyRefNode &ThighHJC=Main.HumanModel.BodyModel.Left.Leg.Seg.Thigh.HipJoint.FemImplantNode;
Ref=0;
Many thanks for your reply!
