In the definition of the AnyDesMeasure we save only one value of each of the vector. How can I save all vector? For example, if I want to run parameter study with 1 parameter and one output function F, how can I get a graphic with axes: 1) parameter, 2) t, 3) F(t) ?
You can try to use time Study.t as the second design variable. But i am not sure that the compiler allows it.
Best regards, Sylvain.
