Question about Recruitment Solvers
I have a question regarding RecruitmentSolvers, specifically the
MinMaxNRSimplex solver (although I’m sure my question applies to the
other Recruitment Solvers as well). I have noticed in the past (and
with the current model that I am working on), that I will occasionally
get the following error when I am adjusting the tEnd and nStep values:
ERROR(OBJ1) : MyStudy’ : Muscle recruitment analysis failed,
simplex solver reports that solution does not satisfy all constraints.
Depending on the tEnd and nStep values I plug in, I can often get the
model to run all the way through. For example, if I have a file that
has a kinematics time frame of 0-58, and a kinetics time frame of
0-116, I have noticed that changing the tEnd and nStep does not always
guarantee that the InverseDynamicsAnalysis will fully run through; I
can have the tEnd be 58/120 (to represent a 120 Hz sampling rate), and
the nStep be 58, and the model will compile and run fine. However, if
the tEnd is (arbitrarily) 30/120, and the nStep is 30, the model will
compile, however it won’t run to completion. And often, the length
that the model will run before failing varies in a non-decipherable
pattern. If my tEnd and nStep is 25, the model may run until 22
before failing – completing nearly the entire analysis. However, if
my tEnd and nStep is 55, the model may run to only 9 before failing –
hardly completing any of the analysis.
I’m sure there is a simple explanation for this which will help in
future analyses and my determination of tEnd and nStep values. Could
you help me out with this? Thank you for your time!
PS – I have uploaded a wheelchair model that I am trying to fully
drive with the addition of trunk movement (right now the trunk is
fixed to the back of the wheelchair – I wrote about two weeks ago with
a question about this model). It currently compiles, but I think
there is a problem with the initial conditions because the left side
of the body does not mimic the right side at load time. It was
working, and I’m not quite sure what I changed, but something seems
amiss…(The file name is SarahArmModel – Muscles_6-11-07).
Hi Sarah
I have uploaded a new version of you application to the file section
of the group it is named “SarahArmModel – Muscles_6-11-07V2” . I
have updated the InitialPosition.any file and made some changes in
the Mannequin.any file so now it loads at a reasonable position and
also run kinematically.
Concerning the MinMaxNRSimplex solver you may experience cases like
you are describing. When the tStart, tEnd or nStep are changed it
means that the analysis will calculate for different time values. If
the model is sensitive this may provoke recruitment problems like
you have experienced. This basically means that a certain or several
dof. in the model are difficult to balance with muscles forces. If
this is the case one solution is to try adding AnyReacForces to the
different dof in the model, if adding a AnyReacForce for a certain
dof in the model makes it stable, it indicates that this dof. is
causing the problem.
The recruitment problem may also occur if there are very strong
muscles present in the problem, this can make the model numerically
difficult to solve. This can be the case if you have strong pushing
muscles for generating support forces to the model, like on a
backrest or similar. So sometimes lowering the strength of these
muscles makes the model more stable.
If you add a small amount of gravity to the directions of the model
having zero gravity, it also often helps making the recruitment more
stable. So something like Gravity = {0.01, -9.81, 0.01}; usually
helps without disturbing the solution of the problem.
The next version of AnyBody will have some additional settings
available in the solver. This can sometimes help solve recruitment
problems if these are caused by numeric problems.
I tried to make your model run inverse analysis, but it seemed that
one timestep was causing problems. The reactions in the GH joint are
created with a number of pushing muscles which ensures that the
reaction force fall with the cavity of scapula. Due to the loading
conditions of this model i tried to change the directional reactions
in the glenohumeral joint back to a classic spherical joint, and it
help solve the problem. To introduce this change to your brep
please do the following changes in Arm3d/jnt.any
1: outcomment the line "#include "“ghreactions.any”
2: change the lines
AnyKinEq GHLinCon = {
AnyKinMeasure &GHLinCon = .GHLin;
Reaction.Type={Off,Off,Off};
to
// Reaction.Type={Off,Off,Off};
the
(and
occasionally
values:
constraints.
the
that
always
I
and
However, if
will
if
failing –
Could
with
side
Just another follow-up question regarding driving a model by mocap data. I have
been looking at the gait webcast from last August, and I am trying to drive the
pelvis in the same way that it is driven in the webcast and I have a question
regarding the statement that RAsisZ + LAsisZ = SacrumZ. Should this be the
average of the two Ases Z-directions? Just adding them together would give a
very tall pelvis, right? Should it be (RAsisZ + LAsisZ)/2 = SacrumZ?
Just trying to figure this out…hope I’m not bothering you!
As always, thanks for your time,
Sarah
-----Original Message-----
> Date: Thu Jun 14 07:56:16 EDT 2007
> From: “AnyBody Support” <support@anybodytech.com>
> Subject: [anyscript] Re: Question about Recruitment Solvers
> Hi Sarah
> of the group it is named “SarahArmModel ? Muscles_6-11-07V2” . I
> 2: change the lines
> to
> Best regards
> S?ren, AnyBody Support
> the
> (and
> occasionally
> values:
> constraints.
> the
> that
> always
> I
> and
> However, if
> will
> > before failing ? completing nearly the entire analysis. However,
> if
> failing ?
> Could
> > PS ? I have uploaded a wheelchair model that I am trying to fully
> > fixed to the back of the wheelchair ? I wrote about two weeks ago
> with
> side
> > amiss?(The file name is SarahArmModel ? Muscles_6-11-07).
Hi Sarah
No problem I will try to explain.
This driver was created because we found that driving for example
the pelvis directly in the z direction was not a good idea, because
and error on leg length joit kinematics would the result in unwanted
rotaions of the pelvis. Therefore we introduced this driver that
makes sure that the pelvis can have variations in height. The driver
says that the height difference between the sacrum marker on the
pelvis and the free floating sacrum marker should be equal the sum
of the the heigth difference between the asis markers.
It is correct that in the Gait3D model the equation
RAsisZ + LAsisZ = SacrumZ is being used
it migth be that
would be better that is correct, this can be tested by chaning the
coefficients. Changing these coefficients will not change the
model dramatically i think, but it is easy to try out.
data. I have been looking at the gait webcast from last August, and
I am trying to drive the pelvis in the same way that it is driven in
the webcast and I have a question regarding the statement that
RAsisZ + LAsisZ = SacrumZ. Should this be the average of the two
Ases Z-directions? Just adding them together would give a very tall
> Sarah
> > From: “AnyBody Support” <support@…>
> > Hi Sarah
section
in
and
like
it
values. If
like
several
If
the
certain
numerically
pushing
model
more
recruitment
that
are
loading
reactions
it
> > 2: change the lines
> > to
> > Best regards
<sarsulli@>
the
to
> > the
past
> > (and
> > occasionally
> > values:
> > constraints.
get
> > the
file
> > that
of
not
> > always
through;
> > I
rate),
> > and
> > However, if
model
> > will
length
decipherable
22
However,
> > if
> > failing ?
help in
values.
> > Could
fully
is
ago
> > with
think
left
> > side
seems
What I understand is that the systems is applying:
u1 + u2 + u3 =0
where u1, u2, and u3 are the differenence between the motion-markers
and body-markers (in y-direction) at RAsisZ, LAsisZ, and SacrumZ,
respectively. There was a small mistake in “JointAndDirvers.any”: they
should be labelled as “RAsisY, LAsisY, and SacrumY”.
I may be wrong.
John
> Hi Sarah
> it migth be that
> Best regards
> — In anyscript@yahoogroups.com, “Sarah R. Sullivan” <sarsulli@>
> > Sarah
> > > From: “AnyBody Support” <support@>
> > > Hi Sarah
> section
> in
> and
> like
> it
> values. If
> like
> several
> If
> the
> certain
> numerically
> pushing
> model
> more
> recruitment
> that
> are
> loading
> reactions
> it
> > > 2: change the lines
> > > to
> > > Best regards
> <sarsulli@>
> the
> to
> > > the
> past
> > > (and
> > > occasionally
> > > values:
> > > constraints.
> get
> > > the
> file
> > > that
> of
> not
> > > always
> through;
> > > I
> rate),
> > > and
> > > However, if
> model
> > > will
> length
> decipherable
> 22
> However,
> > > if
> > > failing ?
> help in
> values.
> > > Could
> fully
> is
> ago
> > > with
> think
> left
> > > side
> seems
Hi John
You are right about this equation and also about the labels, at some
point it was the z direction which was driven, but then this was
changed without changing the labels.
— In anyscript@yahoogroups.com, “johnzengwu” <jwu@…> wrote:
> Hi,
> u1 + u2 + u3 =0
markers
they
> I may be wrong.
> John
wrote:
> > Hi Sarah
example
because
unwanted
driver
sum
> > it migth be that
the
> > Best regards
<sarsulli@>
mocap
and
driven in
two
tall
> > > Sarah
> > > > Hi Sarah
> > section
07V2” . I
changes
> > in
position
> > and
cases
> > like
changed
> > it
> > values. If
> > like
> > several
forces.
> > If
to
> > the
> > certain
dof. is
strong
> > numerically
> > pushing
a
these
the
> > model
recruitment
> > more
usually
settings
> > recruitment
seemed
> > that
joint
> > are
the
> > loading
> > reactions
and
> > it
brep
> > > > 2: change the lines
> > > > to
> > > > Best regards
> > <sarsulli@>
specifically
> > the
applies
> > to
> > > > the
> > past
> > > > (and
> > > > occasionally
nStep
> > > > values:
failed,
> > > > constraints.
often
> > get
> > > > the
a
> > file
> > > > that
frame
> > of
does
> > not
> > > > always
> > through;
> > > > I
sampling
> > rate),
> > > > and
> > > > However, if
> > model
> > > > will
the
> > length
> > decipherable
until
> > 22
> > However,
> > > > if
before
> > > > failing ?
> > help in
> > values.
> > > > Could
to
> > fully
trunk
> > is
weeks
> > ago
> > > > with
I
> > think
> > left
> > > > side
It was
something
> > seems
