Can I ask a question about the script (AnyForce given to the actuator) in “Sit to Stand with exo” model?
What is the VelFactor here? why it should be calculated as that? Thanks a lot
I will try to answer but this feature of the model is also new to me, I understand that these equations can be hard to read.
The equations essentially says.
if the the velocity ref.Vel[0] is larger than or equal to VelLimit, then it will return 1 as the factor if not it will return the sinus equation.
So essentially it is a factor which relates to the speed ankle joint, if the speed is larger than the limit it will be 1 if it is less it will be gradually decrease from 1 as a sinus function.
So the factor will essentially reduce the help from the exo for lower speeds, that is how i understand the code.
