Hi Leng-Feng
You are right about the parser, ver. 3.0 has a more strict type check when
it parses the script than ver. 2, so I had to a few changes in the model to
make rep 5 run on ver. 3
Of Leng-Feng Lee
Sent: 24 February 2009 22:56
Subject: RE: [AnyScript] Question on Computational Speed…
Hi Søren,
Thanks for the reply.
But when I ran Model from Rep. 5 using AnyBody 3.0 I ran into error - I
think the scripting is more strict in AnyBody 3.0?
Anyway, I shall use the latest Rep. in my future model.
btw, the new AnyBody website looks very neat. =)
Leng-Feng
— On Wed, 2/18/09, AnyScript Support <anyscriptsup@
Date: Wednesday, February 18, 2009, 10:28 AM
Hi Leng-Feng
I have checked the speeds in two different ways:
- Running the WheelTurn model from rep. 6 in version 2.0.1 and 3.1
gives the same speed. In 2 min 15 steps is done.
- Running Wheelturn model from Rep 5 in version 2.01 does 25 steps in
2 min so repository 5 is faster than ver. 6
So my conclusion is that the difference in speed; is due to the repository
not AnyBody.
I can not remember all the differences between the two repositories, but
most likely it is caused by the wrapping muscles where the StringMesh
variable may have increased on some the muscles, typically if there is a
wrapping problem we will increase this number which makes it stable but also
slows it down, so I guess during time this number has a tendency to
increase, but it has also improved the robustness.
For some model it may be possible to reduce the StringMesh variable but this
may cause other models to fail, so if you change this variable in principle,
it would be good to test all other models.
There is a download page where you can download all versions of the system,
please see this link http://www.anybodyt ech.com/index. php?id=877
unfortunately ver.1 is missing.
From: anyscript@yahoogrou ps.com [mailto:anyscript@yahoogrou ps.com] On
Behalf
Of Leng-Feng Lee
Sent: 16 February 2009 16:26
Cc: lengfenglee@ yahoo.com
Subject: [AnyScript] Question on Computational Speed…
Hi AnyBuddies,
I use the ‘wheel turn’ model in Repository 5 using AnyBody ‘pre 2.0’ version
and I remember the computation speed is considerably fast.
I recently run the same ‘wheel turn’ model using Repository 6 model with
AnyBody 2.x version but it is somehow slow. Same situation with Repository 7
model with AnyBody 3.0.
I do not have quantitative data to provide here, and I do not have ‘pre 2.0’
version available to run the Repository 5.0 model anymore - using a
non-quantitative comparison: I can sit in front of my PC and get the result
using Repository 5 and ‘pre 2.0’ version in minutes, but with Repository 6.0
and ver 2.x, I can go make a cup of coffee, enjoying it and when I come
back, it is still computing.
Anyone have similar experience? Or any idea why this is happening?
P.S. is it possible to provide AnyBody ver. 1.x to let me try it out?
Leng-Feng
