I’m using for example “AnyFileInputFile” or “AnyFunInterpol” to read in txt-files.
I’d like to parameterize the folder from which this functions should fetch their txt-files.
As an example something like:
AnyString myString = "folder\subfolder\subsubfolder";
AnyInputFile test = {
FileName = "[u][b]myString[/b][/u] est.txt";
Unfortunately it doesn’t work this way.
Is there any opportunity?
Thanks!
Benni
P.S. Because there are several files in the folder “myString” it is no option to name the string directly to the txt-File.
