I have a couple of quick questions I was hoping you could help me out on.
1.) I have complete kinematic and kinetic data on a subject pushing a
wheelchair in my model, however I want to only look at the first half
of my data (the first 13 kinematic data points and the first 52
kinetic data points). So for example, instead of looking at the
entire ~0.4 seconds of data I have, I changed the tEnd to be ~0.2, and
then I halved the nStep value. The model compiles, runs, and my
MuscleCalibrationAnalysis, SetInitialPosition, KinematicAnalysis, and
InverseDynamicAnalysis all seem to work fine. However it appears that
the model is still running my entire data set. How can I be sure
that, for example, if I have a data set of 100 points, that the model
is only looking at the first 50 of them?
2.) For what I am looking at right now, I have a subject who is
pushing constantly at approximately 2 mph. I am synching their
kinematics and kinetics, and inputting that into the model. The data
that I am inputting is a single randomly selected push stroke, so the
subject has already overcome static friction to get the wheelchair
going. Does AnyBody “know” this based on the data I have input? Or
is there some work-around I would have to do to get the model to know
that it isn’t essentially starting from stopped (as it may appear to
the model).
3.) Where can I input a subject’s mass?
4.) I have this problem with one of my muscles. “ERROR:
Supinator_humerus_part_1: Number of allowed iterations for contact
solution has been exceeded in
Main.Model.HumanModel.Left.ShoulderArm.Mus.Supinator_humerus_part_1.SPLine.”
What is the best way to get around this? Should I create an
AnyViaPointMuscle or is there some easier way?
1: The marker drivers in your model all use the same time vector
given in the Kinematics_time.any file, i think. This vector is the
corresponding time values to your marker data. If you change tEnd to
be about half the way through your time range, you will use half of
your data points.
2: Since your are driving the model with measured force data in the
hands, static friction should not be an issue. If there where any
extra friction involved, it is already reflected in the measured
forces.
3: I the main file you can include the AnyMan.any file which
controls the size of the subject. You also need to choose a scaling
law. Please see the main file of the StandingModel to see how it can
be done.
4: The is a muscle wrapping issue, the error occurs because the
muscle wrapping has not converged. The remedy is normally to
increase the StringMesh number of the particular muscle. This is the
variable which controls the discretization of the muscles.
Soeren AnyBody Support
— In anyscript@yahoogroups.com, “Sarah R. Sullivan”
<sarsulli@e…> wrote:
> Hi,
out on.
pushing a
half
and
and
that
model
data
the
Or
know
to
> the model).
PLine.”
> Thanks so much for your help,
> Sarah
