Hi Sashank,
This definitely looks like an infinite loop, that mean the solver
gets stuck in the calculation and will never go to the next step. You
can fix that by changing the solver in the study folder. If you are
now using the MinMaxNRSimplex try to switch to MinMaxSimplex. This
solver is stronger in term of calculation and that usually avoid the
infinite loop problem.
I don’t really know what you mean by “cuff” markers, but I think that
does not really matter. The important thing is to know to which bones
the markers are related to, then you can create and modify all the
markers you want in AnyBody corresponding to the ones of your motion
capture. The Kit-Vaughn set is the one we usually use, but if they
don’t correspond to what you need you can adjust the markers
coordinates and create new markers if you miss some.
Sylvain, AnyBody Support.
— In anyscript@yahoogroups.com, “shashu_23” <shashankraina@…>
wrote:
> Hi Sylvain,
> Thanks for the response, i was able to reduce the muscle
strength
> of the triceps( to a very low number) but when i did this an
> interesting thing happens, the simulation is supposed to go for
> 20steps, but with the reduced triceps strength the simluation goes
> till step 14 (where the hand is about just part the top dead center
> of the wheel) and then it does not go ahead, it does not give an
> error, the processing just keeps going without any results. Have
you
> seen something like this before?
> I think it is taking the optimization routine a long time to find
an
> optimal solution for the problem, but how long i have let the
> simulation run for 20mins with no steps forward or no errors. Would
> like yo hear your thoughts on this.
> 2. This is a different question regarding a different setup. I did
a
> study where i used cuff markers instead of joint landmarks. Should
i
> estimate the markers defined in the Kit-Vaughn marker sets before
> importing the model into AnyBody or is there another way of using
> cuff marker data (like a set of four markers on the forearm).
> Thanks
> Shashank
> wrote:
> > Hi Shashank,
> > 1. If i use AnyMan to change segment lengths with uniform
> > scaling
> > does the ligament lengths automatically get adjusted or do i have
> to
> > run a calibration study.
> > Actually there are no ligaments in this model, but if there where
> > some then yes you should run a calibration study each time you
load
> > the model (no matter if you scale it or not, you have to run it
> > anyway). It is also the case for the MuscleModel_3E: if you use
it
> > you must run the calibration study each time you load the model.
> But
> > you are now using the simple muscle model so it is not necessary
to
> > 2. What is the purpose of the tolerance error. How does it
> > affect the
> > function of the model.
> > I suppose you are talking about the kinematics tolerance, it is
the
> > tolerance of matching of the joints. When you get an error
message
> > saying “kinematics error above tolerance…” that mean some joints
> > cannot match with enough accuracy. It is possible to change this
> > tolerance but it is definitely not a good idea because then your
> > model loose accuracy and you will get noise in the results.
> > 3. If i want to make specific muscles (eg triceps) have low
> > strength
> > or For ex a wheelchair users with C7 level injury does not have
> > control of abdominal musculature what is the best way to
represent
> it
> > in the model.
> > Each muscle have is own muscle model located in BRep in the file
> > Muscle_Parameters, so if you want a specific muscle to be weaker
or
> > stronger you can change the parameters in his own muscle model.
In
> > AnyBody the strength of the muscles is calculated with the PCSA,
> this
> > is the value you have to modify.
> > For the case of the C7 level injury I am not sure of the exact
> > physical consequences on the person you want to add in the model.
> > Does that mean the person is not able to move the lumbar spine?
In
> > that case you should begin by constrain the movement of the spine
> > with drivers. You should also think about whatever the person
need
> to
> > be strapped to the seat or some other things. I guess that also
> mean
> > the person cannot contract his muscles and those muscles remain
> > without any activity, you could represent that behaviour by
setting
> a
> > very low strength to those particular muscles, you can’t totally
> > remove them because the model won’t be balanced anymore.
> > Best regards,
> > — In anyscript@yahoogroups.com, “shashu_23” <shashankraina@>
> > wrote:
> > > Hi Sylvain,
> > > I have a few more generic questions.
scaling
have
> > to
affect
> > the
> > strength
> represent
> > it
> > > in the model.
> > > Thanks
> > > Shashank
> > > wrote:
> > > > Hi Shashank,
> > > > One of the causes of the difference of activity of the
scapular
> > > > muscles can be the shoulder external rotation driver,
precisely
> > the
> > > > one I couldn’t replace by a marker driver. That mean the
> shoulder
> > > > external rotation is fixed instead of following the marker
> > > movement.
> > > > The difference in the motion is not big and as you saw the
> model
> > is
> > > > running, but still that small difference will induce somehow
a
> > > change
> > > > in some muscles activity (most probably in the
shoulder/scapula
> > > > area). That’s why it would be good to have that DOF driven by
> the
> > > > marker.
> > > > It seems your understanding of the simple driver is not
> correct,
> > > > things are like this: when you drive a joint with a simple
> driver
> > > the
> > > > muscles are involved in the inverse dynamics analysis as well
> as
> > if
> > > > you drive it with a marker. There is a parameter in the
Driver
> > > class
> > > > that controls if the muscles will be active or not, it is the
> > > > ReactionType. If ReactionType is “Off” then muscles are
> normally
> > > > caring the load for that joint, if switched “On” the load in
> the
> > > join
> > > > won’t be carried by the muscles but by artificial forces
> > generated
> > > in
> > > > the joint. Default value of ReactionType is “Off”.
> > > > So clearly the difference between those two types of driver
is
> > that
> > > > you cannot drive such complex motion with a simple driver
than
> > with
> > > a
> > > > marker driver. And it affects your model in the way I
explained
> > > > before.
> > > > Best regards,
<shashankraina@>
> > > > wrote:
> > > > > Sylvain,
> > > > > I ran the model and it works fine.
> > > > > I also noticed that the scapular muscles are also active
> (this
> > > was
> > > > > not the case with Rancho model). I will look in and see how
> > drove
> > > > the
> > > > > scapula motion.
> > > > > My question is when we drive something with a simple
driver.
> > That
> > > > > means the muscles for that joint won’t get involved in the
> > > inverse
> > > > > dynamics (am i correct). Could you tell me if it affects
any
> > > other
> > > > > results of the model.
> > > > > Thanks a lot,
> > > > > Shashank
> <support@>
> > > > > wrote:
> > > > > > Hi,
> > > > > > I think one problem comes from the initial position, some
> > > > segments
> > > > > > was not close enough to the marker. So I modified some
> values
> > > in
> > > > > the
> > > > > > mannequin file. I also changed some of the drivers for
the
> > > trunk
> > > > > that
> > > > > > was giving me troubles: I fixed the pelvis to the ground
> and
> > I
> > > > > drive
> > > > > > 2 rotations of the thoracic spine with marker while the
> third
> > > one
> > > > > > keeps giving troubles and I had to drive it with a simple
> > > driver.
> > > > > > I have the model running now but there is a second driver
> (in
> > > > plus
> > > > > of
> > > > > > the trunk rotation) that I could not replace by a marker.
> > It’s
> > > > the
> > > > > > one for the shoulder external rotation. So far I haven’t
> find
> > > > what
> > > > > > cause the error for this driver, it might be a problem of
> > > initial
> > > > > > position again.
> > > > > > I will keep digging the problem. I uploaded the running
> model
> > > > > > (wheel_shank2).
> > > > > > Best regards,
> > <shashankraina@>
> > > > > > wrote:
> > > > > > > Hi,
> > > > > > > I was trying to run a wheelchair model using the
> > template
> > > > > given
> > > > > > in
> > > > > > > WheelChairRancho. I was trying to keep it simple so i
> just
> > > > tried
> > > > > to
> > > > > > > replace the marker data and kept the forces the same.
> > > > > > > Here is what is did.
> > > > > > > 1. The motion markers i have are the same as the ones
in
> > the
> > > > > model
> > > > > > so
> > > > > > > that step is fine.
> > > > > > > 2. I aligned the segments so they are close to the
> markers
> > in
> > > > the
> > > > > > > starting position.
> > > > > > > 3. The model loads up fine. The problem is when i
start
> > > > removing
> > > > > > the
> > > > > > > drivers from the joint and drivers file. I get errors
in
> > > right
> > > > > away
> > > > > > > and i have tried different combinations but it still
> keeps
> > > > > failing.
> > > > > > > 4. I was hoping if someone could look at the model and
> help
> > > me
> > > > > > figure
> > > > > > > out the problem with the drivers. I have uploaded the
> > folder
> > > > > called
> > > > > > > wheel_shank with the model in it. I have also put in
the
> > c3d
> > > > > data
> > > > > > > file if you want it. (as i mentioned before i am still
> > using
> > > > the
> > > > > > > forces from the rancho file as there is some vector
> length
> > > > issues
> > > > > > > with the forces)
> > > > > > > It would be of great help is someone could help me
figure
> > out
> > > > how
> > > > > > to
> > > > > > > solve this problem
> > > > > > > Thanks
> > > > > > > Shashank
