This code means that the robot-human interaction is modeled by 6 dof actuators (muscle of 1kN strength), where linear Y direction is disabled, since the muscle has the strength of 0. Meaning that something else has to carry the Y direction linear loads.
Thank you for your quick reply. What is the reference system of AnyGeneralForce6DOF? Is it the global reference system? If the Y direction is disabled, it means there is no relative movement in this direction, right? I found that the Y direction on the foot is not disabled. Could you explain it to me? Thanks again.
