Recruitment Solvers
Hi Soeren:
I am confused with the choice of recruitment solvers. What I undrstand
is that there are two solvers: linear programming (Simplex) and
quadratic programming (QP), and a combination of these two algorithms
are applied usually. It is possible to choose the recruitment solvers
by adjusting the penalties LP and QP.
So, e.g., RecruitmentLpPenalty=1.0 would mean using 100% linear
programming; RecruitmentLpPenalty=0.5 would mean using 50% linear and
50% quadratic programming. Is it right?
What is the range of variations for these LP and QP penalties?
John Wu
Hi John
You are correct about the solvers there are two types Simplex and QP.
If you specify a linear penalty this will have an effect on both
solvers, but a quadratic penaly will only have an influence if you
are running a QP solver.
The adjustments of the penalty will not change the solver type, this
is set by the solvertype definition.
If you are using a linear penalty of one it will use a objective
function which is the highest activated muscle plus the sum of all
activities.
If the penalties was 0.5Lp and 0.5QP the objective function would be
max activated muscle + 0.5sum of activities + 0.5sum of
activities^2 , the last term would only be in use if the solver is
quadratic.
It is difficult to give a range for the penalties this is a matter
of taste, since it changes how the recruitment is done, but usually
a small linear penalty of for example 1e-5 can be used to avoid
activity “pikes” originating from unwanted co-contraction, since
adding just a small penalty will punish this.
I hope this made things more clear
— In anyscript@yahoogroups.com, “johnzengwu” <jwu@…> wrote:
> Hi Soeren:
undrstand
algorithms
solvers
and
> Regards,
> John Wu
This as actually not completely accurate. The linear penalty has no
effect when you use the quadratic optimizer. The formulation of the
optimization problem is such that you have either linear or quadratic
penalty on the problem, but you cannot have both. If you use the
quadratic optimizer, the linear penalty is ignored even if one if
defined. If you use the simplex optimizer, the quadratic penalty is
ignored.
John
AnyBody Support
wrote:
> Hi John
QP.
this
> activities.
be
> quadratic.
> Best regards
> — In anyscript@yahoogroups.com, “johnzengwu” <jwu@> wrote:
> > Hi Soeren:
> undrstand
> algorithms
> solvers
> and
> > Regards,
> > John Wu
Hi Soeren and John:
Thanks for your responses. It makes sense that only one of the two
optimization methods working at one time, LP or QP. I have tested it,
it really works like that.
I still have problem with the range of variations for LP and QP. What
I understand is that the range of variations should be within 0-1.0.
I have tested that some problems are not sensitive to the penalty
values. These solutions are reliable. However, some problems are
sensitive to the penalty values. The solutions vary with increasing
penalty values. Typically, when LP or QP is taken values > 0.10, the
solutions become stable, no furter variations with increasing LP or QP
values are observed. In this case, I would take LP or QP values to be
0.1. Does this make sense?
Thanks, John
> ignored.
> Best regards,
> John
> AnyBody Support
> wrote:
> > Hi John
> QP.
> this
> > activities.
> be
> > quadratic.
> > Best regards
> > > Hi Soeren:
> > undrstand
> > algorithms
> > solvers
> > and
> > > Regards,
> > > John Wu
Hi John,
I am probably more the recruitment guy around here. I wish is were
easier to write mathematics in this system, but I’ll try in text mode
anyway. The problem we are solving goes like this:
Minimize
Beta + e1sum(muscle stresses) + e2sum(muscle stresses^2)
Subject to
muscle stresses <= Beta
Equilibrium equations
Muscle forces >= 0
e1*e2 = 0
The last conditions expresses that either e1 or e2 must be zero as
mentioned in the previous post. The quadratic optimier can solve any
of the problems while the simplex optimizer can only solve the
problem where e2 = 0. But the simplex optimizer is more efficient and
more robust.
As you can see, with e1 = e2 = 0 we have the pure min/max problem.
When you increae either e1 and e2 from zero towards infinity, the
problem slowly becomes more like either a minimization of the sum or
squared sum of muscle stresses. But mathematically it is neither of
these, unless e1 or e2 has gone to infinity. So e1 = 1 or e2 = 1 will
not mathematically give you what you expected.
Since we cannot set e1 or e2 to infinity, it is relevant to ask: How
large should the be before the problem converts? The answer is that
the effects of e1 and e2 are rather different.
Very small values of e1 might stabilize an ill-conditioned problem
somewhat. So we often use a value of e1 = 1e-5 or thereabout just for
stabilization. The right size depends a bit on the overall activation
level. The problem converts rather rapidly to minimzing the sum of
muscle stress when you increase e1. Usually at e1 = 1.0 the problem
is converted completely.
The effect of e2 is different and actually better from a physiologicl
perspective. Small values of e2 usualy stabilize the problem. But
even e2 = 1 will usually not make the problem completely quadratic.
It will typically act like a quadratic problem for small activaton
levels and like a min/max problem for larger activations. This makes
a lot of physiological sense. To convert the problem completely to
quadrtic form you typically need e2 > 10. I normally use e2 = 1000 to
be sure.
I hope this clarifies the matter. This tutorial explains it in more
detail:
http://www.anybodytech.com/514.0.html
John
> Hi Soeren and John:
it,
What
QP
be
> Thanks, John
no
the
quadratic
is
> > ignored.
> > Best regards,
> > John
> > AnyBody Support
> > wrote:
> > > Hi John
and
> > QP.
both
you
> > this
objective
all
> > > activities.
would
> > be
is
> > > quadratic.
matter
usually
since
> > > Best regards
> > > > Hi Soeren:
> > > undrstand
and
> > > algorithms
> > > solvers
linear
linear
> > > and
> > > > Regards,
> > > > John Wu
