While analysing the forces included in the exported (AnyMechOutputFileForceExport) txt file, I found that some forces are repeated.
For example Force
Main.HumanModel.BodyModel.Trunk.MusclesSpineRight.RectusAbdominis.RA_1
is repeated with two different RefFrames:
Main.HumanModel.BodyModel.Trunk.SegmentsLumbar.PelvisSeg.RA_1_ViaR
Main.HumanModel.BodyModel.Trunk.SegmentsLumbar.PelvisSeg.RA_1_R
Why the force is repeated with two different RefFRames? And how to consider such a force in FEA?
Another Question,
I understood that the sacrum is included within the pelvic ring segment (and also share the same local coordinates frame), however when I needed to export all forces (muscles&joints) associated with the pelvis segment:
I couldn't find two missed forces, which I managed to find when I exported the restults for also sacrum segment:
Main.HumanModel.BodyModel.Trunk.SegmentsLumbar.SacrumSeg
These two forces are:
GluteusMaximusInferior
L5SacrumJnt
Why these two forces are exported only when refering to ".SacrumSeg"
Knowing that many other forces segments are coupled to the sacrum nodes, they still being exported normally when referring to ".PelvisSeg"
Ahmed
